Norrisweb
Slow speed after Engineers visit
An engineer has been around to solve issues with another connection in the flats I live in. Whist doing this he fiddled about with my connection and ever since I've had really slow internet speeds. I'm supposed to be on 200Mb but I'm currently getting less than 10Mb
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)139000000147000000N/A163000000171000000179000000187000000195000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedUnlockedLockedLockedLockedLockedLocked
Channel ID12N/A45078
Modulation256QAM256QAMUnknown256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.952000N/A6.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
N/AI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-6.99-8.89N/A-8.04-9.848.89-8.52-9.88
RxMER (dB)32.8730.53N/A30.8229.310.0029.5730.95
Pre RS Errors194132537975193N/A71221434005034002523807133352356
Post RS Errors43232376714N/A92524231895202732672361
Upstream  US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID2N/AN/A1
Frequency (Hz)39400000N/AN/A46200000
Ranging StatusSuccessOtherOtherSuccess
Modulation64QAMN/AN/A64QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size2N/AN/A2
Power Level (dBmV)54.00N/AN/A54.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
Network LogFirst TimeLast TimePriorityError NumberDescription08/06/2021 10:28:30 GMT08/06/2021 10:28:30 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:28:16 GMT08/06/2021 10:28:16 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:28:00 GMT08/06/2021 10:28:00 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:27:44 GMT08/06/2021 10:27:44 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:27:37 GMT08/06/2021 10:27:37 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:27:25 GMT08/06/2021 10:27:25 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:27:11 GMT08/06/2021 10:27:11 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:26:45 GMT08/06/2021 10:26:45 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:26:21 GMT08/06/2021 10:26:21 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:25:34 GMT08/06/2021 10:25:34 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:25:31 GMT08/06/2021 10:25:31 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync08/06/2021 10:25:16 GMT08/06/2021 10:25:16 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:25:00 GMT08/06/2021 10:25:00 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:25:00 GMT08/06/2021 10:25:00 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:24:32 GMT08/06/2021 10:24:32 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:24:17 GMT08/06/2021 10:24:17 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:24:02 GMT08/06/2021 10:24:02 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:24:01 GMT08/06/2021 10:24:01 GMTCritical (3)84000500SYNC Timing Synchronization failure - Loss of Sync08/06/2021 10:23:43 GMT08/06/2021 10:23:43 GMTWarning (5)84020200Lost MDD Timeout08/06/2021 10:23:31 GMT08/06/2021 10:23:31 GMTWarning (5)84020200Lost MDD Timeout
Andrew-G
  • 9.53K
  • 1.54K
  • 4.56K
Re: Slow speed after Engineers visit
You're quite right, the technician's beggared it all up a treat.  Unless there's a known area fault this will require a further visit.  I've flagged this for staff attention, they'll be able to advise and get a visit booked if needed.
Gareth_L
  • 9.26K
  • 524
  • 1.03K
Hello Norrisweb
I am more than happy to take a look at this for you
And arrange a second visit, This time it will be with a more senior engineer
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
Gareth_L
  • 9.26K
  • 524
  • 1.03K
Hello Norrisweb
Thanks for those details
Just wanted to make sure we got the correct address
I have booked the first engineer appointment we have available
You can check and reschedule this appointment through your online account if you need to
You can also cancel it if the fault has gone
Can you please let me know how the visit goes
Gareth_L
Norrisweb
Just a quick reply to say a big thank you to yourself for the speedy booking and to the engineer who came this morning and solved the problem promptly 🙂
Gareth_L
  • 9.26K
  • 524
  • 1.03K
Hello Norrisweb
That's great news
Just checked the notes now and can see the connections outside on the property were mis fitted
Sorry for the inconvenience this has caused you
I'm just as glad as you that its all fixed now
Gareth_L
