Durkingr
  • 10
Message 1 of 7
Slow speed - M100 service - sure not a fault more network
Hello
I've got M100, using the Hub in Modem mode, with Synology router attached and Mesh WiFi.
I'm experiencing slow speeds during the evening, 20, 30 or 40Mbs max, daytime I get 100Mbs, so I know my system is working OK - how do I get VM to resolve this?
Is it network contention or just VMs backbone?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 7
Re: Slow speed - M100 service - sure not a fault more network
If the slow speed in the evening is a daily occurrence I would say it is a congestion issue.
Durkingr
  • 10
Message 3 of 7
Thanks for the advice... I'll do as you suggest
Durkingr
  • 10
Message 4 of 7
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 7
Can you go into the Synology router settings and allow it to 'Respond to Ping'. [ICMP].
Durkingr
  • 10
Message 6 of 7
just looking to se what to do
Durkingr
  • 10
Message 7 of 7
Think Ive done the ICMP allow
