decwood99
Message 1 of 12
Slow speed Hub4 1gig
Hi so I have had the new hub4 1gig package since last thursday, 09/07/2020.
since having it our wifi went down from a solid 250-300 mbps, anywhere in the house, to around 20-30 mbps, before hand I was on 350m hub3. if I was to do a speed test on my ipad, or any phone in the house, we get about 103ms ping. even hard wired with a cat6 ethernet cable we get about 350-400mbps with the new hub4? anyone had this issue and got any solutions.
This link below shows the internet speed I am getting with the new hub4 1gig, on hard wired.
https://prnt.sc/tj3k50
Tags (3)
jb66
  • 12.28K
  • 912
  • 1.79K
Message 2 of 12
Re: Slow speed Hub4 1gig
decwood99
Message 3 of 12
This is showing 1000mbps+ but isn't that only to show the speed to the router from VM, not the bottleneck
jb66
  • 12.28K
  • 912
  • 1.79K
Message 4 of 12
Yes, this means the fault is likely to be either your equipment or setup rather than the incoming feed
decwood99
Message 5 of 12
so when you say my equipment or setup, are you referring to my computers/phones, or the hub itself?
Anonymous
Not applicable
Message 6 of 12
Does the HUB 4 have any config settings related to QOS?
jhuk
  • 3.03K
  • 52
  • 290
Problem sorter
Message 7 of 12
If you are getting 1000+Mb/s on SamKnows built into the HUB4 then you are getting the correct speed to your home then it is going to be lowered by the 1Gb/s LAN Port  on the HUB4 to about 920-940Mb/s after overheads then if you are only getting 300Mb/s max it is your own devices causing that.
sotonsoldier2k8
  • 79
  • 7
Dialled in
Message 8 of 12
It appears that we are beta testing it 🤢
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 9 of 12
No it appears no one understands networking...
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 10 of 12
Nope.
Same feature-less options as the Hub3.
