Markfreshers
Slow slow slow
I am currently paying for 200mps . Until recently I've been getting around 100-150 which wasn't too bad, however for the past month or two I've only been getting 30-70 and sometimes as low as 10mps. Nothing in my set up has changed and I've been through all the suggested fixes on the virgin site. Any ideas gratefully recieved and I don't fancy sitting o hold for an hour to get through to virgin tech support
conman33158
  • 1.67K
  • 134
  • 364
Super solver
Re: Slow slow slow
Is this wired or wireless connection?
If wireless it sounds like you could be connected to the 2.4Ghz band instead of the 5Ghz band 🙂
BT Full Fibre 900 FTTP - Asus RT-AX82U to Openreach ONT Box & Asus RT-AX56U with AiMesh setup
Ashleigh_C
  • 2.83K
  • 112
  • 234
Re: Slow slow slow
Hi there @Markfreshers
Thank you so much for your post and I am so sorry to see your having these issues with your speeds!
Can I ask if you the advice from @conman33158 has helped, or do you still require assistance?
Thank you.
Ash_C
