Kay, set up a BQM
HERE
Run it for say 24 hrs, and post the result.
It runs their side so you dont need to leave a computer on.
Just to manage expectations, sounds like a wireless issue which is out of VM's pervue. Have you gone though wireless troubleshooting? Have you seprated out the SSID's ? Also try switching intelligent WiFi off....
