markrichards7
  • 16
Message 1 of 25
Slow m200 broadband
So I upgraded my m100 broadband to m100 several months ago and now it's super slow. I have run speed test with a PC connected with cat cable and at best I get 40mb download. Tried phoning 150 but been 2 hours and still not got any answer. Can anyone help please
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 25
Re: Slow m200 broadband
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 25
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 25
Can you please
markrichards7
  • 16
Message 5 of 25
Just checked the download on speetest and its 39Mbps with cable
markrichards7
  • 16
Message 6 of 25
markrichards7
  • 16
Message 7 of 25
Router status
451000000
Locked
Ranged Upstream Channel (Hz)
46200024
Locked
Provisioning State
Online
Back
markrichards7
  • 16
Message 8 of 25
Router status
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
14510000004.840256 qam40
22670000005.638256 qam17
3275000000638256 qam18
42830000006.538256 qam19
52910000006.940256 qam20
6299000000738256 qam21
73070000006.540256 qam22
83150000006.438256 qam23
93230000006.540256 qam24
103310000006.540256 qam25
113390000006.538256 qam26
123470000006.538256 qam27
133550000006.340256 qam28
143630000006.340256 qam29
15371000000640256 qam30
163790000006.138256 qam31
17387000000640256 qam32
18395000000640256 qam33
194030000005.440256 qam34
204110000005.538256 qam35
214190000005.138256 qam36
224270000005.540256 qam37
234350000005.140256 qam38
24443000000540256 qam39
1Locked40.300
2Locked38.640
3Locked38.650
4Locked38.980
5Locked40.360
6Locked38.950
7Locked40.350
8Locked38.950
9Locked40.360
10Locked40.360
11Locked38.650
12Locked38.970
13Locked40.360
14Locked40.350
15Locked40.340
16Locked38.930
17Locked40.9190
18Locked40.3200
19Locked40.340
20Locked38.950
21Locked38.950
22Locked40.350
23Locked40.340
24Locked40.3150
markrichards7
  • 16
Message 9 of 25
Router status
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
14620002445.5512064 qam3
23939998845.5512064 qam4
35369995245.5512064 qam2
46030002945.5512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0010
4ATDMA0000
markrichards7
  • 16
Message 10 of 25
Router status
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
fd;kfoA,.iyewrkldJKDHSUBsgvca
SFID11408
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID11407
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
