KoushaDNava
  • 7
Message 1 of 13
Slow internet speed
Long story short I have finally managed to get a hold of someone at virgin today upgraded my subscription from their 350 package to the 500 package and regardless of a wired connection or a wireless one I cant get the speed over 80 mbps. I have tried every single guide line offered online including turning it off and on, resetting the hub 3, disconnecting all other devices and also having attempted 3 different cable variations just to be sure cat5e cat6 and cats ethernet cable. For wireless connection I am using my note10 plus and wired connection my desktop pc. I need help in figuring out why it doesn't go past 80mbps ?
Tags (3)
KoushaDNava
  • 7
Message 2 of 13
Re: Slow internet speed
Correction where I wrote cats it was meant to say cat8*
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 13
Can you please
Copy and paste the contents of the Configuration Log tab onto here, if you get a yellow / straw box warning click the Post button again.
KoushaDNava
  • 7
Message 4 of 13
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
Vcb573b2ee9a9587e.cm
SFID1071948
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID1071947
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 13
OK.  Your Hub is provisioned for 500Mbs.
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
KoushaDNava
  • 7
Message 6 of 13
on a wired connection to my desktop using a cat6 cable
 PING ms
9
 DOWNLOAD Mbps
90.63
 UPLOAD Mbps
37.02
these speeds are what I was getting from BT more or less hense why I switched over to Virgin, I made the switch about 2 weeks ago
and these issues are starting to get on my last nerve
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 13
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
KoushaDNava
  • 7
Message 8 of 13
for the speed test I used speedtest.net and on the connection status page it states my desktop on ethernet connection and my mobile on wireless
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 13
What is the connection speed reported on that page ?
KoushaDNava
  • 7
Message 10 of 13
everything shows up green and ticked off. their are no red flag no issues reported as far as the admin portal is concerned everything is working as it should. All the other settings are fixed on automatic I cannot change the frequencies or the channels their on in order to see if that would make a difference.
