Samleesauce
  • 7
Message 1 of 13
Slow internet speed.
Can anybody help me. I am currently paying for the 100mbps but I am rarely seeing 30mbps, I read on the virgin site that I should be guaranteed at least 50mbps at all times.
I have reset my hub numerous times, I have hard reset it 3 times and I did get 39mbps for about half an hour.
I have kicked every connection off my hub bar 1 and still struggle to get 40mbps. I have only had virgin for about a month but so far I'm very disappointed, I feel as if I'm paying for a service I am not receiving is there anyone that has Any suggestions please.
Kind regards
gary_dexter
  • 30.67K
  • 1.91K
  • 4.08K
Message 2 of 13
Re: Slow internet speed.
Wired or WiFi?
Samleesauce
  • 7
Message 3 of 13
Both wired and WiFi.... They both give the same readings give or take 1 or 2mbps
gary_dexter
  • 30.67K
  • 1.91K
  • 4.08K
Message 4 of 13
WiFi speeds aren’t covered under the speed guarantee so we’ll disregard those for now.
What device are you testing your wired speeds with and what is the spec of the cable (printed on the cable sheath).
Samleesauce
  • 7
Message 5 of 13
I'm currently testing the WiFi on my pixel 3xl and my desktop pc.
I am currently not at home so cannot provide the cable info but it's the cable that came with my hub 3 if that helps at all.
gary_dexter
  • 30.67K
  • 1.91K
  • 4.08K
Message 6 of 13
Ok.
You'll need to test with a wired connection.
Samleesauce
  • 7
Message 7 of 13
 i did preform one more test before leaving and was shocked that I got over 80mbps this is the first time I have seen anything near that level. I will do another when I get home and find the cable information.
用心棒
  • 5.83K
  • 655
  • 2.03K
Message 8 of 13
@Samleesauce, redact your public IP Address from images before reposting.
Click to learn more about VIP
  Use Kudos to say thanks
Samleesauce
  • 7
Message 9 of 13
Samleesauce
  • 7
Message 10 of 13
So I called up virgin today and ended up buying the bullet and swapping my package from m100 to m350..
I am now getting really good upload speeds but my download speeds have not changed or if they have they have gotten lower ... See pictures, please ignore the test that reads 110mbps download that was done on a another households router (m100 virgin package) just to see if it was working as it should which it is...
Surely with an m350 package I should be getting 3-4 times what I am currently receiving...... Help....
