Hi @delboyuk2508,
Thank you for coming back to us about your ongoing speed issue! Do you have another device that you can run your speed test on to ensure that the results you've had are accurate?
Have you been able to take a look at our Speed Up page to see if this can help with your speed issue? If so, let us know if this improved your speeds at all.
I have been able to run some internal checks on your power levels and they all look good and within spec. Please carry out a Hub Reset to see if this can help with your speeds.
Your connection to your neighbours should not impact your connection to the point that your speeds slow.
Please keep us updated on how you get on so we can help further.
Thank you.
