Trapper1974
  • 12
Message 1 of 5
Slow download speed
I have recently been upgraded to the M200 broadband speed and am only getting approximately 90Mbps speeds.
Information:
  • Hub 2
  • Cat 6 cables
  • Wired connection
  • Factory reset Hub 2 several times
  • No broadband service issues in my area according to the service status page
I have attempted to get a Hub Swap free upgrade to the Hub 3 but it won't allow me to do it on the web page and I have been unsuccessful in getting through to anyone via telephone.
Can anyone advise what my next steps should be?
Tags (3)
dannylau
  • 11.37K
  • 932
  • 2.6K
Message 2 of 5
Re: Slow download speed
90 meg sounds suspisciously like your PC ports are 10/100 rather than 100/1000  what's the make and model of the PC
Trapper1974
  • 12
Message 3 of 5
All my equipment is gigabit and all my cables are cat 6.
This PC's network connection is the onboard LAN adapter of the MSI X570-A Pro (Realtek 8111H Gigabit LAN Controller)
Previously speeds were in the 100 to 150Mbps range.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 5
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Trapper1974
  • 12
Message 5 of 5
Apologies for my slow reply.
Speeds are back to advertised expected speeds for M200 following a factory reset of the Hub. Thank you to those that assisted.
