Vetlondo12
Slow download speed on M350
Hi, I recently changed my packed from M100 to M350. As the first day after upgrade the download speed was around 200Mbps (I checked on wired connection) and for few days is not going over 100Mbps on the wired connection. But the upload speed is reaching between 27-37 Mbps.
Vetlondo12
Re: Slow download speed on M350
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12027500009.338256 qam9
21387500001037256 qam1
31467500001038256 qam2
41547500009.937256 qam3
51627500009.638256 qam4
61707500009.638256 qam5
71787500009.538256 qam6
81867500009.538256 qam7
91947500009.538256 qam8
10210750000938256 qam10
112187500009.138256 qam11
12226750000938256 qam12
13234750000938256 qam13
14242750000938256 qam14
152507500008.938256 qam15
162587500008.838256 qam16
172667500008.838256 qam17
182747500008.938256 qam18
192827500008.437256 qam19
202907500008.538256 qam20
212987500008.437256 qam21
223067500008.638256 qam22
23314750000938256 qam23
243227500008.137256 qam24
1Locked38.680
2Locked37.6500
3Locked38.9210
4Locked37.680
5Locked38.6110
6Locked38.6280
7Locked38.6230
8Locked38.6270
9Locked38.6180
10Locked38.6190
11Locked38.6140
12Locked38.6270
13Locked38.9280
14Locked38.680
15Locked38.970
16Locked38.6110
17Locked38.9140
18Locked38.6100
19Locked37.3250
20Locked38.670
21Locked37.6330
22Locked38.6270
23Locked38.6130
24Locked37.3480
Vetlondo12
1462000003.4512064 qam3
2258000003.4512064 qam6
3326000003.4512064 qam5
4394000003.4512064 qam4
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Buffer6
  • 10.47K
  • 92
  • 614
Hero
Log in to your Hub   http://192.168.0.1/       Hub login  and then click on Connected devices and copy and post the speed you are connected to the Hub
Sometimes the NIC (Network Interface card) is configured wrongly, is going faulty, or not a Gigabit compliant card.
Tags (1)
