CollinIsmael
Message 1 of 5
Slow download speed below 1 Mbps?
My download speed dropped to below 1 Mbps a couple of days ago (on 100 Mbps contract). Upload speed ~5-8 Mbps. Slow download speed has been consistently below 1.5 Mbps for past few days.
Got a new hub 2-3 months ago due to internet dropping from time to time, has been stable since hub replacement.
Disconnected cables/devices and re-tested with same result over wired/wifi.
Anything else can be done about it? Help appreciated.
-tony-
  • 16.56K
  • 1.31K
  • 3.91K
Message 2 of 5
Re: Slow download speed below 1 Mbps?
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
danielwilcox3
Message 3 of 5
I came home today from work to find my router was off, restarted it...my speed is usually 215mbps. I'm getting between 0.5-2mbps now.
jonnismith11
Message 4 of 5
Are you talking about <1ms? You know that’s not your speed right? Check Speedtest.net or fast.com Trace route doesn’t determine your internet speed. It only determines network communication between two points. Trace route ms only determines how long it took for your network to talk to your destination. 9apps
Regards cartoonhd
agnelo3
Just joined
Message 5 of 5
@CollinIsmael wrote:
Have you contacted the support?
