SAkers1975
  • 108
Message 1 of 93
Slow download speed again! - M500 Package
Hi All,
I'm encountering slow download and upload speeds again on my M500 package.
Speed I am currently experiencing below
I'll post some of the logs below from router portal.
Not impressed as I am paying a lot of money a month for this.
We are also getting very poor Wi-Fi speeds upstairs, my wife is unable to stream content from her Amazon Prime without it stuttering or lagging out completely. I have ran the Virgin Media Connect app and it comes back as fine, but the experience tells me otherwise.
I've tried all the usual, reset the router (V3 router), separate the 5Ghz and 2.4Ghz channels, change the channels on the Wi-Fi etc...
There are currently around 13 devices attached, 4 are wired and the rest are wireless.
Since taking up the Virgin contract in February I've ha 3 engineers out, the broadband works for a while then goes back to the current struggles I'm having at the moment with speeds.
Some help on this would be appreciated.
Thanks in advance
Stephen
SAkers1975
  • 108
Message 2 of 93
Re: Slow download speed again! - M500 Package
267000000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
12670000008.338256 qam17
21390000007.638256 qam1
31470000007.938256 qam2
4155000000838256 qam3
51630000008.338256 qam4
61710000008.138256 qam5
71790000008.138256 qam6
81870000008.338256 qam7
91950000008.438256 qam8
10203000000838256 qam9
112110000007.838256 qam10
122190000007.538256 qam11
132270000007.538256 qam12
142350000007.138256 qam13
152430000006.538256 qam14
162510000007.438256 qam15
17259000000838256 qam16
182750000008.338256 qam18
192830000008.338256 qam19
202910000008.438256 qam20
212990000008.538256 qam21
223070000008.538256 qam22
233150000008.638256 qam23
243230000008.938256 qam24
1Locked38.612648514858
2Locked38.688952004080008
3Locked38.623078471225364
4Locked38.646048041972800
5Locked38.977796353559640
6Locked38.9647342732752
7Locked38.969984852142200
8Locked38.63575874414620
9Locked38.636957429646
10Locked38.910923312225
11Locked38.96296320578
12Locked38.67132629549
13Locked38.619951730924
14Locked38.619427230123
15Locked38.611209929921
16Locked38.67959125992
17Locked38.95788019313
18Locked38.94520211653
19Locked38.6331298617
20Locked38.9268199839
21Locked38.9397575653
22Locked38.6256755406
23Locked38.9223185602
24Locked38.9189726039
SAkers1975
  • 108
Message 3 of 93
1603000004.475512064 qam4
2537000004.45512064 qam5
3461999804.45512064 qam6
4394000004.5512064 qam9
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxxl500u+voc-b.cm
SFID901414
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID901413
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling Type
BestEffort
Network LogTime Priority Description
19/05/2020 15:49:5Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 14:59:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 14:59:25Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 14:21:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 14:21:17Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 10:13:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/05/2020 01:33:11ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2020 14:01:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2020 10:50:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2020 08:48:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2020 08:48:2Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2020 08:47:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2020 08:47:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/05/2020 08:47:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 06:17:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 06:17:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 06:12:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2020 06:08:54criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
SAkers1975
  • 108
Message 4 of 93
SAkers1975
  • 108
Message 5 of 93
20/05/2020 15:12:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 15:12:13Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 15:12:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 14:13:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 14:13:23Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 12:22:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/05/2020 08:58:9ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
gary_dexter
  • 30.27K
  • 1.88K
  • 4.02K
Message 6 of 93
Wifi speeds aren’t covered under any guarantees.
What speeds do you get wired to the hub directly?
SAkers1975
  • 108
Message 7 of 93
The router has also been going offline in the early hours of the morning, which lasts for around 5 minutes then comes back again
  • 2.87K
  • 214
  • 607
Trouble shooter
Message 8 of 93
Your PostRS errors are indicating noise on the circuit.  This can be caused by loose connections, check they are all tight.  If the cabling is fine, I suspect an engineer will need to find the source of the noise.  Also your power levels are approaching the upper limit, they should be between -6 and +10, preferably around 0.
SAkers1975
  • 108
Message 9 of 93
I was getting 502MB when I tested last night wired
It's the Wi-Fi which is extremely erratic, I was only getting 14MB's s you can see from my last post.
It's almost unusable upstairs, even though the App is telling me it is fine, it struggles to stream Amazon Prime and Netfilx
For a supposed top tier package in my area, it's leaving a lot to be desired, I purchased a wi-fi extender which was recommended by other members of the community, but this took the speeds down even further and I had to remove it, and I can't get the VM supplied extenders as the app is saying our Wi-Fi is fine.
Frustrated
SAkers1975
  • 108
Message 10 of 93
All connections were checked by the engineer on the last visit, and I have checked today again and they look fine
