sam62
Just joined
Slow broadband
I have 600mb broadband but only getting between 10 & 20mbps on Speedtest. I have tried absolutely everything suggested on VM web pages with no luck.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow broadband
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow broadband
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
