Algill1764
  • 5
Slow broadband
could someone help me, my broadband speed is very slow, I have it hard wired into my laptop and it’s only showing 28mps and I should be on 600mps. I have done all the checks and it hasn’t changed anything.
kev
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow broadband
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Algill1764
  • 5
Re: Slow broadband
Hi MikeRobbo
i have run the tests
ping 15
download 64.85
upload 6.9
hub connection my PC 1000
hope this helps
kev
