Bazza43
Slow broadband
Paying for 200 mbps and just done a speed test and it was 32 mbps. I do have a lot of devices connected 18 in total. Things don't change when I pause some of the devices. Even hard wired devices are slow.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow broadband
Please post a 'Live Link' to your BQM on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow broadband
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
