Lightfantastic
  • 9
Message 1 of 12
Slow broadband
My 200Mbps wired connection has been consistently below 4Mbps since Friday afternoon. I can't get any response from VM to get it fixed. I have checked all cables and restarted/reset several times.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 12
Re: Slow broadband
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
then
 Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
Lightfantastic
  • 9
Message 3 of 12
Re: Slow broadband
I have been using Ookla to measure the speed (recommended by Virgin). I have a Hub 3. Dont know how to get to the hub settings (do you mean using the VM phone app?)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 12
Re: Slow broadband
Forget the phone app, it has more bugs than a tramps vest.
In your browser type 192.168.0.1 into the URL Bar and press enter, then log in to the Hub settings and navigate to the connected devices page.
Lightfantastic
  • 9
Message 5 of 12
Re: Slow broadband
Nice.
PC and Tivo box both 1000Mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 12
Re: Slow broadband
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 7 of 12
Re: Slow broadband
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Lightfantastic
  • 9
Message 8 of 12
Re: Slow broadband
1402750000-7.238256 qam30
2202750000-6.240256 qam9
3210750000-6.240256 qam10
4218750000-6.440256 qam11
5226750000-6.540256 qam12
6234750000-6.740256 qam13
7242750000-6.940256 qam14
8250750000-740256 qam15
9258750000-7.440256 qam16
10266750000-7.540256 qam17
11274750000-7.538256 qam18
12282750000-7.540256 qam19
13290750000-7.538256 qam20
14298750000-7.438256 qam21
15306750000-7.540256 qam22
16314750000-7.540256 qam23
17322750000-7.440256 qam24
18330750000-7.540256 qam25
19370750000-6.740256 qam26
20378750000-6.740256 qam27
21386750000-740256 qam28
22394750000-7.240256 qam29
23410750000-7.240256 qam31
24418750000-7.240256 qam32
1Locked38.960
2Locked40.370
3Locked40.340
4Locked40.360
5Locked40.350
6Locked40.350
7Locked40.360
8Locked40.950
9Locked40.350
10Locked40.350
11Locked38.950
12Locked40.960
13Locked38.950
14Locked38.950
15Locked40.360
16Locked40.340
17Locked40.360
18Locked40.350
19Locked40.300
20Locked40.350
21Locked40.360
22Locked40.360
23Locked40.360
24Locked40.360
Lightfantastic
  • 9
Message 9 of 12
Re: Slow broadband
12579995446.3512064 qam6
23260000747.3512064 qam5
33940003648.8512064 qam4
44619999148.8512064 qam3
3ATDMA0000
4ATDMA0000
Lightfantastic
  • 9
Message 10 of 12
Re: Slow broadband
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cxv9873254k;fg87dsfd;kfoA
SFID13896
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID13893
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
