Milesb84
  • 14
Message 1 of 27
Slow broadband
Broadband is running very slow all the time, had a new router and have boosters but still no help. 
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 27
Re: Slow broadband
Which Hub do you have ?
What is your contracted speed ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Milesb84
  • 14
Message 3 of 27
Re: Slow broadband
I have the latest hub they send out only got a new one on sat, sorry don’t know the exact model.  My contracted speed o believe is at least 100mb plus if not more.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 27
Re: Slow broadband
Can you please
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 27
Re: Slow broadband
vm-hubs
Milesb84
  • 14
Message 6 of 27
Re: Slow broadband
Hub3 is what I have
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 27
Re: Slow broadband
@MikeRobbo wrote:
Can you please
Milesb84
  • 14
Message 8 of 27
Re: Slow broadband
I don’t have a option to check my router status
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 27
Re: Slow broadband
OK, log in and go through the first steps to set up the Hub, then log out and try again.
Milesb84
  • 14
Message 10 of 27
Re: Slow broadband
