chalkyM3
Message 1 of 7
Slow broadband
Had a new cable installed over lockdown to cure drop out and slow speed but still can’t get more than 17-20 mb and more often less than 10mb down and around 12 up. We are area 06. Tried rebooting loads of times VM connect app says everything alright, any help greatly appreciated
Anonymous
Not applicable
Message 2 of 7
Re: Slow broadband
wired or wireless connection when testing speed
chalkyM3
Message 3 of 7
Re: Slow broadband
Wireless, speed is fine wired but despite moving router to every conceivable position, and now having tried VM boosters which knocked internet out altogether I think it’s the router that’s at fault maybe
John_GS
  • 8.72K
  • 476
  • 770
Message 4 of 7
Re: Slow broadband
Hi chalkyM3
Thanks for posting. I am sorry for the lower than expected speeds. I've ran a system check for you today and cannot see anything that would be causing this. Can you post your system logs?
Also, could you try these tips here and here
Kind regards,
John_GS
gary_dexter
  • 30.5K
  • 1.89K
  • 4.05K
Message 5 of 7
Re: Slow broadband
If wired speeds are fine then you need to look into optimising your WiFi.
If that doesn’t make any difference you’ll need to look into putting the hub into modem mode with your own router or look into getting a mesh system or running some wired AP’s.
chalkyM3
Message 6 of 7
Re: Slow broadband
John, how do I find and post system logs?
gary_dexter
  • 30.5K
  • 1.89K
  • 4.05K
Message 7 of 7
Re: Slow broadband
As above.
If wired speeds are fine you need to look at optimising the WiFi.
