only1garibaldi
  • 11
Message 1 of 21
Slow broadband with ethernet cable
I understand Virgin can reduce your internet speed if you are behind with your bill,as my bill is up to date now, my broadband speed is approx half the speed it should be.There is no faults in my area and by running a speed test it says all is ok,this has been going on for 3 days,my question is how long does it take for Virgin to put my speed up to what it should be,I have been trying to work from home but I am restricted,please help
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 21
Re: Slow broadband with ethernet cable
They don't throttle speeds for non payment of bills, they stop the service.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
What is your contracted speed ?
What speed do you get using a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
only1garibaldi
  • 11
Message 3 of 21
Hi Mike,thank you for your quick answer
I have checked service status, there is no local issues,the hub is up against my desk top,my tv and virgin box is downstairs,this is the only problem I have had. this set up has been like this for a couple of years with no problems,I am running on 100 Mbp,cheers Gary
  • 23.88K
  • 2.53K
  • 4.34K
Message 4 of 21
Are you testing on wifi? If you are test over an ethernet cable connection. Test at speedtest.net on a browser an not on the App - which often produces slower speeds.
To rule out your equipment causing the issues, put the Hub into Modem mode and try again on ethernet.
If still low boot the pc/laptop into safe+networking mode and try again on modem mode.
only1garibaldi
  • 11
Message 5 of 21
 speed test,results were 16.70 Mbps and 10.07 Mbps,I only run my pc on the ethernet cable,I am just wondering if it is the router that is at fault and I should ask for a new one,thanks,Gary
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 21
First thing to do is try a different cable.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 21
Log into the Hub Settings and navigate to the Connected Devices Page.
What is the indicated* speed for your PC connection.
* This is the speed the connection is capable of, not the actual speed.
Ideally you want to see 1000Kbs (1Gbs)
only1garibaldi
  • 11
Message 8 of 21
Finally I got through to a voice ,after explaining to the person everything I had done with the advice from the community and the recorded messages he told me there was a local problem,although it says on the portal there is no problems and it will be fixed by 6pm this evening,and at 3.55pm I received a txt from Virgin saying this issue is now fixed.....well its not,I am still having the same problem
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 21
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
only1garibaldi
  • 11
Message 10 of 21
Thank you for all your help,I have just tried what you suggested but its still the same,I am going to ring them again today
