on 05-09-2023 21:06
Why is the broadband speed significantly reduced in the bedrooms compared with the living room where the router is? The house is not big, and we don't have lots of devices connected at the same time.
on 05-09-2023 21:13
That's WiFi for you on cheap rented kit!
Confirm you are getting full speed to the HUB over the VM network:
https://samknows.com/realspeed/
06-09-2023 15:24 - edited 06-09-2023 16:09
Is the house constructed of foot thick stone walls - or iron rich Victorian red bricks - or with insulating foil backed plasterboard walls - with underfloor electric heating cables ..... any of which would put you in a nice "Faraday Cage" and block you wifi signal 😎
More likely just reduced signal and set up at the locations - what Hub model is it and what channels are you using?
on 06-09-2023 16:23
Read this. UNDERSTANDING KEY ASPECTS OF WiFi - Virgin Media Community - 3870538
