Borisbear
  • 5
Slow broadband speed
Our broadband is running really slow, 18mbps when it should be about 100mbps. An engineer replaced our external box the other day and it seems slower since then. Any ideas?
  • 14.06K
  • 1.88K
  • 4.32K
Re: Slow broadband speed
Hi @Borisbear
You should post your router stats here for the learned members to check what the problem is and offer assistance.
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) and hit return.
Don't login, instead below there click on Check Router Status
From the Router Status” page copy/paste 3 FULL sets of data onto here – from the Downstream, Upstream, & Network Logs pages.
You could also set up a BQM monitor  at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK.
Dave
Paulina_Z
  • 4.31K
  • 159
  • 327
Hi @Borisbear,
Welcome back to our Community Forums! Thank you for your post, and I'm sorry to hear that you're unhappy with your current speeds.
What speeds are you getting on a wired connection at the moment?
Have you tried to use different Ethernet cables to see if there is a difference in speeds?
Have you re-booted your Hub since the technician appointment?
I was able to locate your account and I can see that your upstream power levels are out of spec at the moment.
Please give these suggestions a try and let us know how you get on. If your power levels do not change, we will look into this issue further for you and look at booking in another technician appointment,
Keep us updated.
Thank you.
Paulina_Z
