T1695
Slow broadband speed
I have been experiencing extremely slow broadband speed over the last three weeks. I subscribe for 200mbs but barely get 30 at sometimes. Cannot get through customer service. Have checked and rebooted the router number of times - no joy
i in Birmingham B26 area. Is there anything else I can do??
the level of service is getting really bad
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow broadband speed
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
T1695
See attached router
most speed test have been WiFi
Up to 23 Oct I was getting between 160-190 on WiFi speed, now most days it around 60 and some days I get 20.
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
@T1695 wrote:
See attached router
VM do not, and never have guaranteed Wi-Fi speed or coverage.
The problem with Wi-Fi is that it can be brilliant at breakfast time and useless by lunchtime and you haven't changed anything, BUT, something, somewhere has changed, then you can spend hours and even days trying to find a fix for something that can be totally out of your control.
If you remove all the internal walls, water, electronic and electrical devices, metallic pipes and conduits and wrap the whole building in a thick lead shield you will have a good chance of getting decent Wi-Fi from an ISP Hub.
Just a few things that can affect Wi-Fi in the average home …
Blockage (visible) …
Mirrors, furniture, fish tanks, people, radiators, walls, flooring / ceilings.
Interference (invisible) …
Cordless phones, baby monitors, microwave ovens, fridges & freezers, TVs, next doors Wi-Fi and Wi-Fi equipment, DAB transmitters, the list is endless.
My VM Hub 3 Wi-Fi went into meltdown when the local authority / police CCTV camera on the lamppost adjacent to my house was used.
Many people have accepted that the VM Wi-Fi is poor and have purchased third party equipment that is much, much more powerful than the VM supplied kit and once set up have wondered why they waited for so long.
