JohnMorr
  • 20
Message 1 of 5
Slow broadband speed
Spoiler
Have tested download speed 3 to 28 should be towards 100.
Used independently 2 laptops & 1 Android phone. Also used ethernet cable.
Disabled Channel optimization & set to 20/50/80.
Max speed 25ish but can drop to 11
Did once show 55 but not on retest so scope is there
Worrying as dropped connection during video conferencing
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Slow broadband speed
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
JohnMorr
  • 20
Message 3 of 5
Hob 3.0 28 download & 8.9 up
JohnMorr
  • 20
Message 4 of 5
Same as wifi. Disabled Channel Optimization & set to 20/50/80
Hub 3.0 says Connected devices wifi for
my laptop 52.73 Speed (Mbps) 2.4 G &
other laptop 571.28 Speed (Mbps) 5G
JohnMorr
  • 20
Message 5 of 5
Today download speed has varied from 4.41 Mbps (5g work laptop dropped out) up to 82.46 Mbps but mainly around 20ish. I have not made any changes.
Hob 3.0 has given
my 2.4 G laptop max speed as 145.09 Speed (Mbps)
2.4 G smart TV max speed as 103.02 Speed (Mbps)
Still waiting technical support from Virgin Media - 3 days waiting
