speedman2006
Slow broadband speed
In the last 2 weeks experienced slow speeds and from yesterday speed dropped to under 2mbps on download and 3-4mbps on upload.
i have an 350mbps plan and 30 mbps upload.
i cannot watch tv because of slow speeds,barely can open internet pages.
i unplugged the power several times,restarted the hub 4-5 times.
i have a hub 3,the only thing i haven’t done is to reset it.
I really need my internet,i did ringed to customer service but nobody answered,waited over 20minutes.
Thank you
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow broadband speed
How are you connecting your device, Wi-Fi or ethernet cable ?
speedman2006
Cable to my pc and Wi-Fi to phone and tablet.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
