Robert190388
  • 30
Message 1 of 11
Slow broadband speed
Hello any virgin media team around? The engineer come out twice today because I have slow speeds. But he can’t find a fault swapped out my router for new one still didn’t fix my slow speeds. I’m on m350 package And my speeds are ranging 140 to 200?
enginner said my speeds are far to slow. But can’t find fault.
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Message 2 of 11
Re: Slow broadband speed
What speeds? Wired or wireless?
Robert190388
  • 30
Message 3 of 11
93 mbps cat 5 yeah I’m upgrading for gaming. WiFi 200. The engineer said thers an issue but it’s not showing up so he can’t fix it. Even phoned the woman i was talking to said there is a fault.
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Message 4 of 11
CAT5 maxes out at 100Mbps so 93Mbps with a CAT5 cable is spot on.
CAT5e/6/7 will give you speeds up to 1GB.
200Mbps on wifi is also about right.
Robert190388
  • 30
Message 5 of 11
You say WiFi is about right  been with virgin 2 years now my speeds always been to 350 never dropped out till 3 weeks Ago? Virgin woman on the phone said your speeds should not drop below 300 ever unless thers a fault.
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Message 6 of 11
They can’t guarantee wifi speeds - the person on the phone doesn’t know what they’re on about.
It only take on small environmental change to knock wifi off-kilter such as a neighbour getting a new router etc.
Have you looked into optimising the wifi channels?
Robert190388
  • 30
Message 7 of 11
optimising not sure what that means?
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Message 8 of 11
Getting your own (better) equipment and running it alongside the virgin hub
Robert190388
  • 30
Message 9 of 11
What router do you recommend /equipment?
gary_dexter
  • 30.28K
  • 1.88K
  • 4.03K
Message 10 of 11
If you want to improve Wi-Fi across your property then a mesh system like BT Whole Home will work, or if you can run cables then some wired Uniquiti Access Points.
Failing that another router will work such as an ASUS AC86U and run the virgin hub in Modem Mode.
