bondquest
  • 126
  • 13
Dialled in
Slow broadband speed in DN32
I've been getting very poor broadband speed all day in DN32 (Grimsby). It comes and goes, and sometimes isn't available.
If anyone else in the area reads this, and is having a problem let me know, so at least i know it's not my individual connection or router. I know we pay a fortune to Virgin, but I guess we shouldn't expect a decent service 100% of the time.
I've run a speedtest (over wi-fi, as who has an ethernet cable these days), and the ping's around 26ms, and the download speed was between 6Mbps and 16Mbps, when I'm getting a connection.
Let's see whether I can post this message.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow broadband speed in DN32
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
bondquest
  • 126
  • 13
Dialled in
Speed has been up and down over the last 3 weeks or so.
Should I be happy with 21Mbps on a Saturday afternoon, when I pay for 200Mbps?
I've just rebooted the hub as it was crawling along at 4Mbps
Downstream
12030000001.740256 qam9
22110000001.738256 qam10
32190000001.740256 qam11
42270000001.538256 qam12
52350000001.438256 qam13
62430000001.240256 qam14
7251000000140256 qam15
8259000000140256 qam16
92670000001.240256 qam17
102750000001.240256 qam18
112830000001.540256 qam19
122910000001.538256 qam20
132990000001.938256 qam21
143070000001.940256 qam22
15315000000240256 qam23
16323000000240256 qam24
17331000000240256 qam25
183710000001.540256 qam26
193790000001.538256 qam27
203870000001.440256 qam28
213950000001.540256 qam29
224030000001.440256 qam30
234110000001.438256 qam31
244190000001.440256 qam32
1Locked40.350
2Locked38.950
3Locked40.350
4Locked38.960
5Locked38.930
6Locked40.360
7Locked40.350
8Locked40.350
9Locked40.950
10Locked40.350
11Locked40.360
12Locked38.950
13Locked38.9120
14Locked40.3190
15Locked40.350
16Locked40.350
17Locked40.300
18Locked40.300
19Locked38.940
20Locked40.340
21Locked40.360
22Locked40.350
23Locked38.970
24Locked40.370
Upstream
13260000038512064 qam3
24620000039512016 qam1
33940000038.5512064 qam2
42580000037.5512064 qam4
2ATDMA0010
3ATDMA0000
4ATDMA0000
Config
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID246152
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID246151
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
bondquest
  • 126
  • 13
Dialled in
Here's the network log
TimePriorityDescription19/12/2020 15:52:48noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;15/12/2020 18:04:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;15/12/2020 00:55:57ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;12/12/2020 11:59:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;11/12/2020 22:51:41ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/12/2020 22:16:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;09/12/2020 22:15:34Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;07/12/2020 10:50:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;07/12/2020 00:40:22ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/12/2020 20:06:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/12/2020 12:40:21ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/12/2020 06:29:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;30/11/2020 16:47:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/01/1970 09:42:23ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;02/01/1970 09:39:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:00:25ErrorToD request sent- No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/01/1970 00:01:49Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/11/2020 19:33:36ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;23/11/2020 20:41:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/11/2020 07:33:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
