Spix83
  • 11
Message 1 of 14
Slow broadband, constantly resetting my hub
My broadband is consistently slower than the minimum guaranteed speed of 107Mbps. Resetting the hub usually rectifies this (not always). I have made contact and been chatting to resolve it and was referred to the phone line means of communication. 40 minutes of terrible hold music followed be disconnection. After resets the speed is brilliant but it does not last. Do I need a new hub?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 14
Re: Slow broadband, constantly resetting my hub
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Spix83
  • 11
Message 3 of 14
My BQM
Spix83
  • 11
Message 4 of 14
Downstream
1 202750000 2.2 37 256 qam 9
2 210750000 1.9 37 256 qam 10
3 218750000 1.5 37 256 qam 11
4 226750000 1.2 37 256 qam 12
5 234750000 1.2 37 256 qam 13
6 242750000 1 37 256 qam 14
7 250750000 1 37 256 qam 15
8 258750000 0.9 37 256 qam 16
9 266750000 0.7 37 256 qam 17
Spix83
  • 11
Message 5 of 14
1 53700000 51 5120 64 qam 2
2 60300000 51 5120 64 qam 1
3 39400000 51 5120 64 qam 4
4 46200000 51 5120 64 qam 3
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Spix83
  • 11
Message 6 of 14
17/10/2020 16:25:22 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/10/2020 09:28:59 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 23:45:48 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 11:47:2 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 11:35:13 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Spix83
  • 11
Message 7 of 14
How long does it take for someone to analyse the data requested above?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 14
It seems odd that you have 9 Downstream Channels, which Hub do you have ?
Your Upstream Power levels are maxed out and will need an engineer to put them right.
You can either phone in (08:00 is the best time) or wait on here for a few days until one of the VM Forum Staff comes along.
Spix83
  • 11
Message 9 of 14
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12027500002.437256 qam9
22107500002.237256 qam10
32187500001.737256 qam11
42267500001.537256 qam12
52347500001.437256 qam13
62427500001.237256 qam14
72507500001.237256 qam15
8258750000137256 qam16
9266750000137256 qam17
102747500000.737256 qam18
112827500000.437256 qam19
122907500000.236256 qam20
132987500000.237256 qam21
143067500000.237256 qam22
15314750000037256 qam23
16322750000-0.437256 qam24
17402750000-2.737256 qam25
18410750000-2.737256 qam26
19418750000-337256 qam27
20426750000-3.237256 qam28
21434750000-3.437256 qam29
22442750000-3.537256 qam30
23450750000-3.537256 qam31
24458750000-3.537256 qam32
1Locked37.3500
2Locked37.3470
3Locked37.6630
4Locked37.3860
5Locked37.3680
6Locked37.3970
7Locked37.31280
8Locked37.6940
9Locked37.31870
10Locked37.61850
11Locked37.32290
12Locked36.62160
13Locked37.31960
14Locked37.31760
15Locked37.31650
16Locked37.31880
17Locked37.35500
18Locked37.35680
19Locked37.36990
20Locked37.38360
21Locked37.39510
22Locked37.39600
23Locked37.310270
24Locked37.311670
Spix83
  • 11
Message 10 of 14
This broadband speed problem still remains, less than 40Mbps this morning! What is the point of a guaranteed minimum speed of 107Mbps if you can't meet it?
