djb3
  • 13
Message 1 of 10
Slow broadband and occasional TV Pixilation
I am on the Ultimate Oomph Bundle and should be getting M500 fibre broadband. The actual speed I get is approx. 170 Mbps. If I connect via ethernet it may go up to 180 Mbps. I have been monitoring this for weeks. I have rebooted the router and it doesn’t make any difference. I have also reset it and once again no difference. I have checked the cables. I also sometime get pixilation on my V6 box.
On a previous contract I was on 350 Mbps and I nearly always got 375 Mbps whether connected by ethernet or wirelessly.
I would be grateful if someone could take a look at my stats and give me some advice.
Many thanks
Dave
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
483000000
4.6
38
256 qam
30
2
187000000
4.9
38
256 qam
7
3
195000000
4.1
37
256 qam
8
4
203000000
4.1
37
256 qam
9
5
211000000
4.3
38
256 qam
10
6
219000000
4.9
38
256 qam
11
7
227000000
5.1
38
256 qam
12
8
235000000
5.1
40
256 qam
13
9
243000000
5
38
256 qam
14
10
251000000
5
38
256 qam
15
11
259000000
4.6
40
256 qam
16
12
267000000
4.5
38
256 qam
17
13
275000000
4.6
38
256 qam
18
14
283000000
4.9
40
256 qam
19
15
291000000
5
40
256 qam
20
16
299000000
5
38
256 qam
21
17
307000000
5
40
256 qam
22
18
315000000
5.3
40
256 qam
23
19
323000000
5.6
40
256 qam
24
20
443000000
3.9
38
256 qam
25
21
451000000
3.9
38
256 qam
26
22
459000000
4.1
38
256 qam
27
23
467000000
4.4
38
256 qam
28
24
475000000
4.4
38
256 qam
29
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
11925
489
2
Locked
38.6
394
0
3
Locked
37.6
379
0
4
Locked
37.6
535
19
5
Locked
38.9
366
0
6
Locked
38.9
334
0
7
Locked
38.6
315
0
8
Locked
40.3
317
0
9
Locked
38.9
356
0
10
Locked
38.9
330
0
11
Locked
40.3
319
0
12
Locked
38.9
334
0
13
Locked
38.9
324
0
14
Locked
40.3
337
0
15
Locked
40.3
380
0
16
Locked
38.9
379
0
17
Locked
40.3
345
0
18
Locked
40.3
333
0
19
Locked
40.3
366
0
20
Locked
38.6
6340
10
21
Locked
38.6
30088
30635
22
Locked
38.9
10646
4365
23
Locked
38.6
9858
1099
24
Locked
38.6
14136
4894
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60299581
4.75
5120
64 qam
6
2
46200156
4.675
5120
32 qam
8
3
39400000
4.65
5120
32 qam
9
4
53700000
4.65
5120
64 qam
7
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
17/08/2020 07:23:13
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2020 01:41:26
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/08/2020 09:38:12
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/08/2020 06:48:4
critical
12/08/2020 12:32:23
notice
12/08/2020 11:56:51
critical
12/08/2020 08:41:45
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 12:40:10
notice
09/08/2020 04:27:30
critical
07/08/2020 14:54:17
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/08/2020 14:54:16
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/08/2020 14:54:12
critical
07/08/2020 14:54:11
Warning!
07/08/2020 14:54:11
critical
07/08/2020 14:54:11
Warning!
07/08/2020 14:12:15
critical
07/08/2020 14:10:27
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/08/2020 14:05:43
Warning!
07/08/2020 14:05:39
critical
07/08/2020 14:05:39
Warning!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: Slow broadband and occasional TV Pixilation
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
djb3
  • 13
Message 3 of 10
Hi Mike
Sorry for the delay in replying. Below is the direct link to BQM
https://www.thinkbroadband.com/broadband/monitoring/quality/share/5e9ee9f972a38d60995d4ab37f01988e08...
 To put you in the picture my connection is fairly stable and has been for months. but it feels as though it has been capped at about 170Mbps and I am supposed to be on 500Mbps
Many thanks
Dave
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 10
Your >> BQM << looks pretty good.
Can you do a couple of speed tests at >> speedtest.net << using a direct connection with a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then post the results on here.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 10
Can you go back into the Hub Status page and copy and paste the contents of the Configuration tab please.
djb3
  • 13
Message 6 of 10
Speedtest as follows plus Config details
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxxl500u+voc-b.cm
SFID655790
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID655789
Max Traffic Rate38520000
Min Traffic Rate0
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 10
You need to pass this on to VM now, there is nothing more we can do.
For sanity reasons, I would wait for one of the VM Staff to pick up the thread or phone first thing in the morning.
You can contact VM to report your problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
Lisa_CC
  • 3.97K
  • 236
  • 438
Moderator
Moderator
Message 8 of 10
Hi @djb3 and sorry to hear about your connection speed issue. I've had a look at your live network details and cannot see any issues whatsoever. There are no congestion or utilisation issues either. I've looked at your WiFi and can see some issues with the 2.4Ghz and so I'm wondering whether there is an issue with the Hub. The tiny errors I can see for WiFi could be something within your home and not Hub related but I've ordered a replacement for you just so we can rule it out.
It may take up to 5 days for it to arrive and please let us know how it goes.
Lisa
djb3
  • 13
Message 9 of 10
Hi Lisa
Thanks for that. On a previous contract with Virgin I was on 350 Mbps and I used to get 375 Mbps most of the time and that was wireless but with this router nowhere near even though it is in exactly the same place with just the same things connected.
Thanks for your help. I'll let you know how I get on.
Dave
djb3
  • 13
Message 10 of 10
Hi Lisa
I have received the new hub and have been using it for a couple of days and it appears to have made a big improvement. I have not noticed any pixilation  on my V6 box and there is a definite improvement in speed. I have had speeds of over 500 Mbps a couple of times and that was wireless.
Once again thank you for your help
Dave
