Paulwibble
Slow broadband Need Engineer.
New to cable having come off telephone connection. Contract for 200mbps getting no where near as low as 9 and never over 50. I need an engineer but 150 is always engaged. I have turned off then on, reset, tried it wired and wireless, cat 5 cable. so very disappointed after waiting for ages for installation.  I made a complaint.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Slow broadband Need Engineer.
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
