dkintheuk
  • 8
Message 1 of 13
Slow broadband M500 running at between 150 and 200Mbps
I've tried everything you recommend and several things that I have read about elsewhere.
I cannot get the speed of my broadband above 250Mpbs and this has been the same for most of the time I've been a customer.
The router reports the Acquired Downstream Channel as 619000000.
So why is the actual connection so slow?
I'm using a wired connection directly to the router and separately via a switch but I get the same speed report either way.
Please help.
Rob.
  • 6.1K
  • 513
  • 1.57K
Message 2 of 13
Re: Slow broadband M500 running at between 150 and 200Mbps
Post the power levels, Pre and PostRS errors and Network log from the Hub.  Also setup a BQM here www.thinkbroadband.com/ping
Once done we can comment on your circuit.  Do not use screenshots, just copy and paste into several posts, thanks,
dkintheuk
  • 8
Message 3 of 13
Ok...
I hope this is what you need.
Power Levels...
15370000046512064 qam2
23940000043.5512064 qam4
34620000044.5512064 qam3
46030000046512064 qam1
Here is the Network Log...
05/12/2021 12:13:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/12/2021 05:58:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2021 19:02:0noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/12/2021 19:02:0ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/12/2021 05:32:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2021 07:02:0noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2021 07:02:0ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2021 16:02:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2021 04:59:37noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2021 04:59:37ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2021 04:19:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2021 13:59:42noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2021 05:56:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2021 05:56:35criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2021 05:55:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2021 05:55:39criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2021 05:54:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2021 05:54:43criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2021 05:53:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I'm not sure what you mean by Pre and PostRS errors - where do I find that info?
Do you want the link to the BQM?
  • 6.1K
  • 513
  • 1.57K
Message 4 of 13
Pre and PostRS errors are in the Download section, if you could post those please. Also post the link to the shared BQM graph .
dkintheuk
  • 8
Message 5 of 13
Download section? Do you mean in the router settings? Or is this from somewhere else?
Here is the link to the BQM graph...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/902dc28b61c550cfc0063899a5d67b04f9...
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 6 of 13
Downstream tab - same place as the Upstream you posted but a different tab!
dkintheuk
  • 8
Message 7 of 13
Aha... gotcha!
Here you go...
1619000000-438256 qam27
2475000000038256 qam9
3483000000-0.240256 qam10
4491000000-0.538256 qam11
5499000000-138256 qam12
6507000000-1.238256 qam13
7515000000-1.538256 qam14
8523000000-1.938256 qam15
9531000000-1.738256 qam16
10539000000-238256 qam17
11547000000-1.538256 qam18
12555000000-1.738256 qam19
13563000000-1.738256 qam20
14571000000-2.438256 qam21
15579000000-2.738256 qam22
16587000000-2.538256 qam23
17595000000-338256 qam24
18603000000-3.538256 qam25
19611000000-438256 qam26
20627000000-4.238256 qam28
21635000000-437256 qam29
22643000000-3.738256 qam30
23651000000-3.538256 qam31
24659000000-338256 qam32
1Locked38.939850
2Locked38.98490
3Locked40.39120
4Locked38.911000
5Locked38.911500
6Locked38.611470
7Locked38.912740
8Locked38.619710
9Locked38.614850
10Locked38.916920
11Locked38.917510
12Locked38.919451
13Locked38.919673
14Locked38.624390
15Locked38.929260
16Locked38.933360
17Locked38.631610
18Locked38.942510
19Locked38.637930
20Locked38.957287
21Locked37.659340
22Locked38.657610
23Locked38.955500
24Locked38.9620814
dkintheuk
  • 8
Message 8 of 13
It's all gone very quiet...
dkintheuk
  • 8
Message 9 of 13
So, I had a sales cal from Virgin to buy a new contract... I've got 6 months left on this one. I explained my woes with the setup and that I was unhappy with the speed I was getting. They said they'd get someone to call.
I'm guessing that it was not really Virgin and I'm beginning to think that they don't give a flying potato about an of their customers.
Off to Twitter I go...
Zoie_P
  • 4.86K
  • 203
  • 376
Message 10 of 13
Hi dkintheuk,
Thank you for your reply 🙂
I am sorry to hear you have been having speed issues.
I would advise not popping over to Twitter, we are the same team and we are limited over Twitter.
I have checked your account and all looks fine, I can see you have not rebooted in over 16 days if you could reboot for us, please?
I can also see our systems are advising one of your devices is too close.
Zoie
