sasp
  • 7
Message 1 of 7
Slow and wobbly upload causing latency issues
Hi all,
Hope i can get some help here, I am not that technical so please go easy on me.
Having an issue with my connection speed, its hard to explain as when I do a speed test I get around 200mb download but the upload is all over the place
It will hover at 1 to 1.5 mbs for most of the test, sometimes in the last second of the test it will accelerate rapidly up past 10 mbs but this is maybe 1 or 2 times out of 10
Its causing weird latency issues in the remote desktop connection I am using to work from home at the moment (thanks covid)
I am not sure what info is needed so I will put up everything I guess may be relevant
Thank you in advance for any help
08/10/2020 10:43:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 10:43:40Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:19:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:19:12criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:16:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:16:32criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:12:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:12:32criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:05:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:05:41criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:04:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 07:04:33criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 06:53:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 06:53:42criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 06:52:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 06:52:34criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 06:51:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 06:51:2criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 06:49:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/10/2020 06:49:54criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1402750000-12.536256 qam25
2218750000-8.937256 qam11
3226750000-9.237256 qam12
4234750000-9.737256 qam13
5242750000-10.237256 qam14
6250750000-10.437256 qam15
7258750000-9.537256 qam16
8266750000-9.237256 qam17
9274750000-9.438256 qam18
10282750000-9.537256 qam19
11290750000-9.737256 qam20
12298750000-9.737256 qam21
13306750000-1037256 qam22
14314750000-10.737256 qam23
15322750000-10.537256 qam24
16410750000-1336256 qam26
17418750000-1336256 qam27
18426750000-12.736256 qam28
19434750000-13.236256 qam29
20442750000-1336256 qam30
21450750000-1336256 qam31
22458750000-13.535256 qam32
23466750000-13.535256 qam33
24474750000-13.736256 qam34
1537000005.1512032 qam2
2393999355.1512064 qam4
3461999085.1512064 qam3
4603000005.1512064 qam1
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 7
Re: Slow and wobbly upload causing latency issues
Your Downstream Power Levels are far, far too low and your Upstream Power Levels are are right on the max.
You need an engineer to put things right.
You can either phone in (08:00 is the best time) or wait on here for a few days until one of the VM Forum Staff comes along.
sasp
  • 7
Message 3 of 7
Thanks Mike,
Its annoyingly intermittent but I can manage with it so I'll wait for the VM Forum staff I think
Appreciate the help
sasp
  • 7
Message 4 of 7
Its working a lot better this afternoon, I have not been with Virgin long and wonder if the bad weather (wind and rain) here this morning could have been a cause some how
sasp
  • 7
Message 5 of 7
Still having issues, cant find a pattern or reason to it but it seems to be getting worse
Upload speed today just 0.18 Mbps - please can I get some help from Virgin on this matter now please
sasp
  • 7
Message 6 of 7
Issue is back again today - under 0.2mbs upload causing me to get kicked off my work phone software....
I know it must be irritating keep bumping this thread but I really would like someone from virgin to take a look now and having tried phoning today and just being told to restart and reset my hub I am getting a bit frustrated
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 7
Bumping your post puts it lower down the 'VM Reply' to list.
