Slow and variable speed - unreliable connection
Hi, i've been having issues with my connection speed for about 6 months now and its deteriorated so much now that i can't even watch a programme on any streaming service without extreme buffering, in some cases i just have to give up. I have tried the customer services route but it's taken 3 weeks for someone to ask me to do a wired speed test and i just can't waste the time trying to sort it with them. I don't think the problem is the headline speed, its more the variability of the speed.
So far I have done a series of WiFi and wired speed tests using the recommended speedtest.net but also the automated testing from testmy.net for some 'soak' tests. Results below:
WiFi (Speedtest.net): Min 8.99Mbps, Max 53.2Mbps, average over 24 hours of random tests (15 test points) 22.6 Mbps
Wired (Speedtest.net): Min 24.7 Mbps, Max 54.3 Mbps, average over 15 hours of random tests (12 test points) 34.3 Mbps
Wired (testmy.net): Min 1.83Mbps, Max 54.41Mbps, average over 12 hours of hourly test points with wifi disabled on hub 3.0 (12 test points) 24.88 Mbps
I have included the status and config data from my Hub 3.0 below.
Let me know if anything else is needed, hope you can help!
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
259000000
13.4
40
256 qam
16
2
203000000
13.5
38
256 qam
9
3
211000000
13.5
38
256 qam
10
4
219000000
13.5
40
256 qam
11
5
227000000
13.1
38
256 qam
12
6
235000000
13.3
38
256 qam
13
7
243000000
13.1
38
256 qam
14
8
251000000
13.3
40
256 qam
15
9
267000000
13.5
38
256 qam
17
10
275000000
13.5
38
256 qam
18
11
283000000
13.6
38
256 qam
19
12
291000000
14
40
256 qam
20
13
299000000
14.3
38
256 qam
21
14
307000000
14.4
40
256 qam
22
15
315000000
14.4
40
256 qam
23
16
323000000
14.5
40
256 qam
24
17
363000000
14.1
40
256 qam
25
18
371000000
14.1
40
256 qam
26
19
379000000
14.1
38
256 qam
27
20
387000000
14
40
256 qam
28
21
395000000
14
40
256 qam
29
22
403000000
14
40
256 qam
30
23
411000000
14
38
256 qam
31
24
419000000
14
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
89
0
2
Locked
38.9
33
0
3
Locked
38.6
43
0
4
Locked
40.3
42
0
5
Locked
38.9
45
0
6
Locked
38.9
41
0
7
Locked
38.9
25
0
8
Locked
40.9
45
0
9
Locked
38.9
33
0
10
Locked
38.9
28
0
11
Locked
38.9
51
0
12
Locked
40.3
35
0
13
Locked
38.9
113
0
14
Locked
40.3
36
0
15
Locked
40.3
60
0
16
Locked
40.3
47
0
17
Locked
40.9
36
0
18
Locked
40.3
44
0
19
Locked
38.9
37
0
20
Locked
40.3
40
0
21
Locked
40.3
37
0
22
Locked
40.3
22
0
23
Locked
38.9
58
0
24
Locked
40.3
63
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300000
4.15
5120
64 qam
1
2
53700000
4.1
5120
64 qam
2
3
46200000
4.025
5120
64 qam
3
4
39400000
4
5120
64 qam
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
10/10/2019 00:28:26
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2019 00:28:26
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2019 00:28:26
Warning!
10/10/2019 00:28:26
critical
10/10/2019 00:28:30
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2019 00:31:8
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2019 00:38:44
critical
10/10/2019 04:29:15
Warning!
10/10/2019 04:29:16
critical
10/10/2019 04:29:16
Warning!
10/10/2019 04:29:16
critical
10/10/2019 04:29:20
Warning!
10/10/2019 04:31:26
critical
10/10/2019 04:39:6
critical
15/10/2019 16:59:31
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2019 20:34:34
critical
16/10/2019 02:31:7
Error
  • 15.56K
  • 1.63K
  • 2.65K
Re: Slow and variable speed - unreliable connection
Downstream power levels are all out of spec. +10dBmv is the recommended maximum level.
Will need a technician to visit to correct these.
Calling it in as a fault should be quicker than waiting for a VM response on here - that can be a few days.
Thanks jbrennand, i'm due call back on the issue so will put that into the mix too. Looking at the installation i already have 3 attenuators fitted so i wonder what more can be done to manage the power.
  • 6.02K
  • 307
  • 535
Hi Jim_bob,
Thanks for posting and welcome to the community. I am sorry for the broadband issues. I've ran a check on the account today and all levels are in spec, how are things since posting?
Please let me know if there's anything further I can assist with?
Kind regards,
John_GS
Hi John_GS, one of the chaps at work had a spare 6dB attenuator so I gave that a try and it’s pulled the power levels back in check. So far all good! Thanks for looking into the issue for me.
  • 1.35K
  • 45
  • 122
Moderator
Moderator
No worries Jim_bob,
Thanks for letting us know. Please give us a shout if you need any further support going forward.
Kind regards,
Dean C
