rbrucey
Message 1 of 9
Slow and intermittent despite ethernet
Have been paying for 200mbs for many months, Connection has been horribly intermittent over much of lockdown and became unusable last week. Engineer visited and swapped 'pin' in the pit in the street. Things appear more stable but am only getting 60-90mbs download speed and around 20mbs upload. Have factory reset hub, checked all connections, Why am I getting nowhere near what I'm paying for...?
Router status stats as follows:
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
8
37
256 qam
25
2
203000000
8.4
37
256 qam
9
3
211000000
8.4
37
256 qam
10
4
219000000
8.1
37
256 qam
11
5
227000000
8
37
256 qam
12
6
235000000
7.9
37
256 qam
13
7
243000000
7.8
37
256 qam
14
8
251000000
7.8
37
256 qam
15
9
259000000
8
37
256 qam
16
10
267000000
8
37
256 qam
17
11
275000000
7.9
37
256 qam
18
12
283000000
7.8
37
256 qam
19
13
291000000
8
37
256 qam
20
14
299000000
8
37
256 qam
21
15
307000000
8
37
256 qam
22
16
315000000
8.1
37
256 qam
23
17
323000000
8
37
256 qam
24
18
339000000
7.8
37
256 qam
26
19
347000000
7.5
37
256 qam
27
20
355000000
7
37
256 qam
28
21
363000000
7.4
37
256 qam
29
22
371000000
7.5
37
256 qam
30
23
379000000
7.6
37
256 qam
31
24
387000000
7.6
37
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.6
1438
1367
2
Locked
37.3
5450
2879
3
Locked
37.6
5733
2513
4
Locked
37.6
6131
2224
5
Locked
37.3
5517
2304
6
Locked
37.6
4345
1948
7
Locked
37.6
3709
1557
8
Locked
37.6
2667
1750
9
Locked
37.6
2653
2053
10
Locked
37.6
3159
2104
11
Locked
37.6
3189
1584
12
Locked
37.3
3024
1544
13
Locked
37.6
2556
1328
14
Locked
37.6
2667
1354
15
Locked
37.3
1693
1464
16
Locked
37.3
1281
1270
17
Locked
37.3
1380
1333
18
Locked
37.3
1565
1424
19
Locked
37.3
1546
1309
20
Locked
37.3
1649
1066
21
Locked
37.3
1514
1613
22
Locked
37.3
1278
2044
23
Locked
37.3
1132
2288
24
Locked
37.3
989
2199
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60299979
3.825
5120
64 qam
1
2
39400087
3.6
5120
64 qam
4
3
46200000
3.725
5120
32 qam
3
4
53700073
3.725
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
13/10/2020 14:06:22
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 13:12:5
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 13:10:10
notice
13/10/2020 12:48:21
critical
13/10/2020 12:38:7
Warning!
13/10/2020 12:38:6
critical
13/10/2020 12:32:58
Warning!
13/10/2020 12:28:42
critical
13/10/2020 12:28:42
Warning!
13/10/2020 12:27:15
critical
13/10/2020 12:26:27
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 12:18:45
critical
13/10/2020 12:18:45
Warning!
13/10/2020 12:16:38
critical
13/10/2020 12:16:38
Warning!
13/10/2020 12:13:23
critical
13/10/2020 12:13:0
Warning!
13/10/2020 10:56:31
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 10:05:24
critical
13/10/2020 10:05:24
critical
Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 24K
  • 2.54K
  • 4.36K
Message 2 of 9
Re: Slow and intermittent despite ethernet
The frequent T3's are a worry. So...Can you switch the Hub off for 5 minutes and on restart check that the RS errors have all reset to 0 and then check regularly that they are not reappearing - they shouldn't.
Also see if the one up channel on 32 qam has reverted to 64.
Finally, if you haven’t already, set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” (as per instructions on the TB website) when you have the first 24h period.
rbrucey
Message 3 of 9
Hi John,
Many thanks for speedy reply. Did as you suggested. RS errors have not reset to 0 and the up channel on 32 is still on 32...
What's next?
R
  • 24K
  • 2.54K
  • 4.36K
Message 4 of 9
Odd! Switch the Hub off and unplug it from the power - wait 5 minutes and switch it on - see if that sorts it
rbrucey
Message 5 of 9
Hi John,
I turned the hub off for ten minutes as suggested. The upstream channels are now all 64. However still loads of RS errors in the network log. And speed getting worse: now 55/15 mbs download/upload.
I have installed the broadband quality monitor. Results here:
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/0e4c91c2dd47c15e8c7dfce46ad5c7bb40622bdd-15-10-2020]My Broadband Ping[/url]
Clearly something is not right. Full router stats to follow.
Richard
rbrucey
Message 6 of 9
Router status:
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
6
37
256 qam
25
2
203000000
6.4
37
256 qam
9
3
211000000
6.3
37
256 qam
10
4
219000000
6
37
256 qam
11
5
227000000
6
37
256 qam
12
6
235000000
6
37
256 qam
13
7
243000000
6
37
256 qam
14
8
251000000
6
37
256 qam
15
9
259000000
6.1
37
256 qam
16
10
267000000
6
37
256 qam
17
11
275000000
5.8
37
256 qam
18
12
283000000
5.8
37
256 qam
19
13
291000000
6
37
256 qam
20
14
299000000
6.1
37
256 qam
21
15
307000000
6.3
37
256 qam
22
16
315000000
6.5
37
256 qam
23
17
323000000
6.1
37
256 qam
24
18
339000000
5.6
37
256 qam
26
19
347000000
5.4
37
256 qam
27
20
355000000
5
37
256 qam
28
21
363000000
5.4
37
256 qam
29
22
371000000
5.5
37
256 qam
30
23
379000000
5.9
37
256 qam
31
24
387000000
5.9
37
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
1021
672
2
Locked
37.6
2055
1105
3
Locked
37.3
1883
1202
4
Locked
37.6
1965
779
5
Locked
37.3
1872
765
6
Locked
37.3
2068
654
7
Locked
37.6
2050
856
8
Locked
37.6
1770
870
9
Locked
37.6
1638
1060
10
Locked
37.6
1648
943
11
Locked
37.6
1504
785
12
Locked
37.6
1473
669
13
Locked
37.3
1376
745
14
Locked
37.6
1891
784
15
Locked
37.3
1654
680
16
Locked
37.3
1034
598
17
Locked
37.3
959
766
18
Locked
37.3
1019
806
19
Locked
37.3
1058
648
20
Locked
37.3
1095
594
21
Locked
37.3
1294
1010
22
Locked
37.6
1165
1047
23
Locked
37.3
1156
1209
24
Locked
37.3
1032
1108
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300000
3.9
5120
64 qam
1
2
39399930
3.75
5120
64 qam
4
3
46200004
3.8
5120
64 qam
3
4
53699925
3.85
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
15/10/2020 09:55:51
Warning!
15/10/2020 09:52:47
critical
15/10/2020 09:52:46
Warning!
15/10/2020 09:52:45
critical
15/10/2020 08:58:55
Warning!
15/10/2020 08:50:52
critical
15/10/2020 08:50:51
Warning!
15/10/2020 08:00:39
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 07:49:2
Warning!
15/10/2020 07:47:23
critical
15/10/2020 07:47:23
Warning!
15/10/2020 07:32:21
critical
15/10/2020 07:32:21
Warning!
15/10/2020 06:55:2
critical
15/10/2020 06:28:29
Warning!
15/10/2020 06:28:28
critical
15/10/2020 05:57:9
Warning!
15/10/2020 05:57:7
critical
15/10/2020 05:49:14
Warning!
15/10/2020 05:48:25
critical
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 9
Your >> BQM << is a mess.
If those RS Errors have built up over a couple of hours you have a problem that needs VM to look at.
You can either phone in (08:00 is the best time) or wait on here for a few days until one of the VM Forum Staff comes along.
Gareth_L
  • 6.92K
  • 424
  • 780
Message 8 of 9
Hello rbrucey
Sorry to see this has happened again
I did check few things from here and the upstream is a bit out, well 2 channels are way out
Which would need another engineer i'm afraid to say
I have booked the first engineer appointment we have available
You can check and reschedule this appointment through your online account if you need to
You can also cancel it if the fault has gone
Can you please let me know how the visit goes
Gareth_L
Fadzer
Message 9 of 9
Hi Gareth,
I'm have the exact same issue. Slower speeds (70-80mbps) than what i paid for (200) and it keeps dropping out. I'm trying to work from home with remote access and its constantly dropping out. Very frustrating.
VM have sent out a new SH3 and i'm still having the same issues. An engineer came but frankly did nothing said his phone said everything was ok so there was nothing he could do other than give me some ethernet cables to check. Even though i told him i've tried plenty and still have the same problem.
I hope what i've coped and pasted below is the right info but this is all a bit beyond me, with channels etc. Please can you help no one else in Virgin seems to be able.
Hope to here from you soon
thanks
Niall
