Mickmcg
Slow and intermittent broadband
Diagnostics are telling me there are no problems in my area, Wirral, but the speed and availability have been rubbish since midday today. This has now become a daily occurrence. I can’t get through on the phone and the online help sends me in a loop with no resolution. This is simply not good enough. I will be switching supplier as soon as possible.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow and intermittent broadband
Then
Can you please
David_Bn
  • 5.4K
  • 247
  • 447
Good Afternoon Mickmcg,
Thanks for your post on our Community Forums and a very warm welcome to you!
Sorry for the time it's taken to respond to you and for the issues you've been experiencing with our services.
Looking into the local area, there does appear to be an outage that is running until 9am tomorrow morning.
Our team will do everything they can to have this cleared for you by this estimated fix time
Apologies for any inconvenience this may cause you
Kindest regards,
David_Bn
