Rita3366
  • 6
Message 1 of 12
Slow Wifi
Dear All, can someone please help with an issue that seems to be very common on this site. I’m experiencing exceptionally slow download (1.86 Mb/s) and upload (0.51) speeds for a M200 plan. i have done all the checks suggested by the website as well as spent 46mins waiting around 13:16, 50 mins around 14:02 and 57 mins around 14:52 on hold over the phone today only to be cut off. What a way to spend a Sunday afternoon!
I am getting rather desperate as I work for the NHS and need to see patients on Zoom.
Here is some additional info after typing in 192.168.0.1 downstream
14027500002.438256 qam30
2202750000238256 qam9
32107500001.937256 qam10
42187500001.738256 qam11
52267500001.737256 qam12
62347500001.538256 qam13
72427500001.237256 qam14
82507500001.537256 qam15
92587500001.938256 qam16
102667500002.237256 qam17
11274750000237256 qam18
122827500002.438256 qam19
132907500002.538256 qam20
142987500002.737256 qam21
153067500002.738256 qam22
16314750000338256 qam23
17322750000338256 qam24
18330750000338256 qam25
19370750000238256 qam26
203787500002.237256 qam27
213867500002.237256 qam
 UpstreamnnelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID1536999914.425512064 qam22394000004.425512064 qam43462000004.425512064 qam34603000074.425512064 qam
network data
01/11/2020 21:35:39Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 21:33:52noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 21:32:31Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 21:12:51noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 18:39:14Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 18:39:11criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 18:39:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 18:39:10Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 18:39:10criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Any help would be greatly appreciated. Thank you.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 12
Re: Slow Wifi
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 12
Re: Slow Wifi
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Rita3366
  • 6
Message 4 of 12
Re: Slow Wifi
Thanks for such a prompt reply.
download speed is 1.86 Mb/s and upload speed is 0.51
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 12
Re: Slow Wifi
Is that using an ethernet cable connected device or by Wi-Fi ?
Rita3366
  • 6
Message 6 of 12
Re: Slow Wifi
Downstream
72427500001.437256 qam14
112747500002.237256 qam18
213867500002.237256 qam28
223947500002.538256 qam29
234107500002.537256 qam31
244187500002.238256 qam32
Rita3366
  • 6
Message 7 of 12
Re: Slow Wifi
Ethernet
Rita3366
  • 6
Message 8 of 12
Re: Slow Wifi
UChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
4603000074.425512064 qam1
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 12
Re: Slow Wifi
What device are you connecting the cable to ?
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
Rita3366
  • 6
Message 10 of 12
Re: Slow Wifi
Network log
01/11/2020 18:39:11criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=c0:05:c2:
