Mrswoody
  • 17
Message 1 of 34
Slow Wifi
over the last few months my wifi speed has been slowing down.  I can no longer get a good signal in a couple of my rooms.  I have just watched the video about improving wifi and found out that the hub should not be on the floor or next to any furniture.  If I had known that i would have changed the position, but there is no give in the wires.  Seems strange that the technician would install it like this but fail to mention it.
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 2 of 34
Re: Slow Wifi
Are wired connections working OK?
Its the engineers job to install the hub and how WiFi is setup and optimised is down to the user.
Mrswoody
  • 17
Message 3 of 34
Re: Slow Wifi
Wired devices are fine.
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 4 of 34
Re: Slow Wifi
The you need to optimise the WiFi (split the WiFi bands, move to cleaner channels etc) or failing that purchase a better router or mesh system.
Mrswoody
  • 17
Message 5 of 34
Re: Slow Wifi
sounds technical, but i will give it a go.  thank you
Anonymous
Not applicable
Message 6 of 34
Re: Slow Wifi
Could you access your router using http://192.168.0.1/ .
Log in using the password on the base of the router, unless you've already changed it.
Navigate to Advanced Settings \ Wireless \ Security
You will see two sections, one for 2.4 Ghz and one for 5 Ghz. Change each 'SSID' to something different to identify which one to connect to. Personally I appended the existing name with '_2G' and '_5G'.
At the very bottom click 'Apply Changes'.
Note you will need to reconnect all wireless devices as the SSID (Network Name) will have changed.
When re-connecting use the '_5G' name if it's visible, if not use '_2G'.
Mrswoody
  • 17
Message 7 of 34
Re: Slow Wifi
fantastic - thank you
Anonymous
Not applicable
Message 8 of 34
Re: Slow Wifi
I'm not guarenting it will help, however at least you can 'force' your devices to connect to what should be a faster band on the router.
Mrswoody
  • 17
Message 9 of 34
Re: Slow Wifi
Thanks.  I have gone into the settings and there are only 2 devices on 2.4.  When I run the diagnostic tool, the result is showing that the home network has a few problems, but I am not sure what to do next?  Any idea.
Anonymous
Not applicable
Message 10 of 34
Re: Slow Wifi
Did you make the changes I suggested?
What was it saying regarding problems?
I've just run it on my router and it's telling me that most of my wireless devices aren't close enough to the router. It's a pretty rubbish conclusion as they are all fine!
