Tancom
  • 5
Message 1 of 8
Slow Wifi - average 30 on 350mb
I have been having issues with the speed of my wifi connection, I have recently had my HUB replaced after an engineer visit, but speeds are still poor. Both on my phone and laptop, I have not been able to do a test via ethernet as my laptop does not have an ethernet connection - not standard on modern laptops!
Network Log Downstream bonded channels
1723000000-138256 qam40
2539000000-2.438256 qam17
3547000000-2.538256 qam18
4555000000-2.238256 qam19
5563000000-2.238256 qam20
6571000000-2.238256 qam21
7579000000-2.238256 qam22
8587000000-2.238256 qam23
9595000000-2.438256 qam24
10603000000-2.238256 qam25
11611000000-2.238256 qam26
12619000000-2.538256 qam27
13627000000-2.438256 qam28
14635000000-238256 qam29
15643000000-238256 qam30
16651000000-238256 qam31
17659000000-238256 qam32
18667000000-238256 qam33
19675000000-238256 qam34
20683000000-1.738256 qam35
21691000000-1.538256 qam36
22699000000-1.538256 qam37
23707000000-1.238256 qam38
24715000000-138256 qam39
1Locked38.965423253
2Locked38.935864413
3Locked38.636622332
4Locked38.940302401
5Locked38.649131452
6Locked38.951936463
7Locked38.954618479
8Locked38.646088570
9Locked38.947904677
10Locked38.664267719
11Locked38.967657740
12Locked38.971060653
13Locked38.676277553
14Locked38.984562508
15Locked38.668820605
16Locked38.677859502
17Locked38.679740502
18Locked38.975819539
19Locked38.683171531
20Locked38.674772585
21Locked38.661974480
22Locked38.667584634
23Locked38.660020365
24Locked38.958867
223
Tags (3)
Tancom
  • 5
Message 2 of 8
Re: Slow Wifi - average 30 on 350mb
Due to the 20k character limit, I am posting the upstream and network log below;
15370000248512064 qam10
23940000046.5512064 qam12
34620005647.5512064 qam11
46030000048.5512064 qam9
1ATDMA0050
2ATDMA0030
3ATDMA0030
4ATDMA0020
21/11/2020 10:51:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 01:01:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 22:45:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 20:15:11noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 20:15:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 08:21:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 08:15:11noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 08:15:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 07:45:11noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 07:45:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 21:54:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 19:45:10noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 19:45:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 18:55:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 07:26:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 07:26:24ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 11:11:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 02:49:48noticeSW download Successful - Via NMS
09/11/2020 02:47:35noticeSW Download INIT - Via NMS
08/11/2020 08:28:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 8
You really do need to test with an ethernet connection so that you can determine whether you have a WAN Service problem or a local Wi-Fi problem.
You can purchase USB to ethernet gigabit dongles from the usual online suppliers.
Tancom
  • 5
Message 4 of 8
I seem to be getting good speeds when connected via a cable, 378Mbps, via wifi at same location 202Mbps, but on my phone using the speed test.net app I am currently maxing out at 39.9MBps, in a secondary room with a wifi booster i wasnt even able to connect to the speed test, despite showing connection to the router etc.
This problem seems to be intermittent, even causing issues with wifi printing, even though all devices showing a good connection to the wifi.
Any advice on how this can be fixed?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 8
If your ethernet connections are good but Wi-Fi is bad you need to obtain some third party equipment that is much, much more powerful than the VM supplied kit and once set up have wondered why they waited for so long.
Spondodge
  • 14
Message 6 of 8
The WiFi settings can be adjusted on homehub 3 to increase your WiFi speed internally. Just copy screenshot settings.  The thing that is making the difference is the Channel Width settings.  Setting it to 20/40/80 made a significant difference to my wifi speedtests when in the same room as the router. It was suggested by someone on here last summer. Note it doesn't speed up the downstream/upstream connections your router has to the outside world just speeds up the wifi connection between a device and router inside the home.
in a web browser navigate to 192.168.0.1
login with setting password from bottom of homehub.
from menu down left goto advanced settings > wireless > wireless signal
Disable channel optimisation, select 20/40/80 from channel width drop down. I leave channel as auto and I tick enable 5ghz.
Under wireless security section down left menu you can rename your network wireless name (SSID)  for the 2.4ghz or 5ghz. I like to separate mine with a _5G after the name on the 5ghz so I can specifically connect to the 5Ghz version on devices that support the faster WiFi.
What this will do is when you search for wireless networks on the device your connecting from it will show "VM2123457_5G" and "VM21234567"  or whatever you have renamed them to for the 2.4ghz and 5ghz wireless connections.
Tancom
  • 5
Message 7 of 8
Thanks for the advice - are there any features to particularly look out for to improve on the Vigin hub? I always assumed the way they marketed it it was the bees knees.
Tancom
  • 5
Message 8 of 8
Thanks I have made these changes on my router - initial speed test has shown a marked improvement, from 160 to 200Mbps, but will monitor over the coming days.
Does anyone have any experence with the Wifi Boosters? I have a pair that have been ghosted to the router, and have tried to connect via the LAN connection to the laptop but the connection on the laptop shows no internet connection via the wire, only shows via wifi connection.
