Slow WiFi
swarfy
I have m200 volt and always had over 100mbs download speed noticed I had problems recently and on checking daily my speed is only about 30mbs what on earth is happening if I can't get the correct speed I will go elsewhere and pay a lot less
2 REPLIES 2
jhuk
Trouble shooter
Test it wired and if not ok then post your issue in the WIFI section.
Steven_L
Hey @swarfy,
Welcome to the community and thanks for taking the time to post your issue on the forums.
I’m sorry to hear of the issues that you’re having with your WiFi connection at the moment,
I have looked into your connection and that in the local area and cannot see any issues. How are things looking at the moment on your end?
Regards,
Steven_L
