ChrisHaslam
Message 1 of 7
Slow WiFi with intermittent issues
For the last couple of months our WiFi speed has been only 4mbps. Every time I check the service status it says there is an intermittent issue, 'a blip in the network' but this never seems to be resolved.
The hub itself is fine, and I have gone through all the fixes suggested online and on the phone to no avail. Not sure what else to do?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 7
Re: Slow WiFi with intermittent issues
Which Hub do you have ?
What is your contracted speed ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
ChrisHaslam
Message 3 of 7
Hi Mike
Thanks for the reply. We have Hub 3.0, contracted speed should be 108Mbps.
Right now, on your link via WiFi I'm getting 5.49 download Mbps. Hard cabled in the download speed is 15.21 Mbps.
Chris
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 7
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 7
Can you please
ChrisHaslam
Message 6 of 7
Hollie_B
  • 932
  • 45
  • 60
Message 7 of 7
Hi there @ChrisHaslam
Welcome to the community and thank you for your post. Apologies for the delay in response and to hear you've been having trouble with your broadband connection.
How has it been since? Have the speeds improved at all? Are you able to run a wired test with just that device connected?
Hollie - Forum Team
