shangardezi
  • 33
Message 1 of 13
Slow WiFi and frequent drop outs
Hi team,
I'm increasingly getting frustrated with Virgin Media's service. The internet drops out frequently and we're getting sub-par speeds. I'm on the 200mbps package and even with a wired connection I'm only getting 90 - 95mbps, over WiFi it's 50mbps at best.
The router wasn't installed in the best place (in a bedroom on the floor), an engineer advised to install power-line adapters as Virgin will charge £100 to move the router. Virgin installing the router in a bad place and then charging me to install it in a better place is ridiculous.
Outages in our area so common and bill credit is never issued, regardless if you register loss of service.
I'd really appreciate some help here as we're professionals in our household and rely heavily on a good connection to work from home. Our contract expires next month so if we're unable to get the advertised speed and whole house coverage, we'll simply move provider.
gary_dexter
  • 30.4K
  • 1.88K
  • 4.04K
Message 2 of 13
Re: Slow WiFi and frequent drop outs
Do you work from home all the time or just due to COVID?
When testing wired speeds are you wired direct to the hub and not via any Powerlines, switches etc?
Note that guaranteed speeds are for speeds delivered to the hub only and not WiFi speeds, and “whole house” coverage is also not part of any guarantees.
shangardezi
  • 33
Message 3 of 13
More so now because of COVID, otherwise I usually worked from home 3 days a week. The wired speeds I quoted are direct from the hub.
gary_dexter
  • 30.4K
  • 1.88K
  • 4.04K
Message 4 of 13
90Mbps via a cable would indicate either a CAT5 cable or the Ethernet adaptor on the device is only limited to 100Mbps and is not Gigabit enabled.
shangardezi
  • 33
Message 5 of 13
I'll look into that.
I get 30mbps over wifi standing right in front of the hub. Can someone please look into this?
gary_dexter
  • 30.4K
  • 1.88K
  • 4.04K
Message 6 of 13
Via what device?
shangardezi
  • 33
Message 7 of 13
Hub 3
edit: via my android device and macbook
gary_dexter
  • 30.4K
  • 1.88K
  • 4.04K
Message 8 of 13
What are wired speeds like?
I know you posted previously about 90-95Mbps and that would usually indicate a CAT5 cable and/or an Ethernet port not supporting Gigabit
shangardezi
  • 33
Message 9 of 13
I'll look into the type of ethernet cable I'm using, though the wifi speed needs to be looked at.
Can someone from Virgin please help?
gary_dexter
  • 30.4K
  • 1.88K
  • 4.04K
Message 10 of 13
WiFi speeds form no part of any speed guarantee
