02-01-2024 19:54 - edited 02-01-2024 19:57
Hello, I'm on VM 250/25 ( volt) since early last month upload speed has been less than 2mbs on the Router directly with ethernet. Unable to make video calls.
Router says:
30/12/2023 19:36:49criticalNo Ranging Response received - T3
( Multiple occurrences of this)
Also, packet loss.
Engineer has been to property and "fixed" cabling. -They Checked internal cables and covered box on front of property. Told me speed would gradually increase. No difference.
** My thoughts are it's a SNR issue & most likely the cable between the first floor flat and box located on the ground floor**
Mixed service update messages on progress, time keeps moving forward. Postcode and service messages unreliable.
Latest:
Virgin Media Outage Update - Description: Service update. Broadband, Voice and TV fault F011135676. The latest update we have is: Our engineer is on site and they're working to fix the problem. The estimated repair time is now: 03/01/2024 09:00:00. The Virgin Media Team.- ID: F011135676. Best wishes, the Virgin Media Team.
Any help would be gratefully received, can't be chasing this every day. Thanks
Answered! Go to Answer
on 04-01-2024 15:00
Post upthe full data set like this...
____________________________
Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 04-01-2024 15:00
on 06-01-2024 11:48
Thank you very much. In the future will do this. Now working absolutely fine, turned out was SNR outage. VM were very helpful. The only confusing thing is multiple sources of conflicting updates. From this though, I've gained a network at full speed and thorough check of internal & external wiring to the box at least.
