davestretch
  • 11
Message 1 of 23
Slow Upload speed - KT4 area
Hi - my download speed is consistent but the upload speed fluctuates wildly throughout the day and I am lucky if I get 10Mbps (often hovers around 5Mbps) when I should get 36Mbps on my package.
I get these speeds both via wired and Wi-Fi connections.
The only time I get the full upload speed is 1st thing in the morning and from 9am and onwards it varies greatly.
I have a Hub4 - any suggestions on settings to check or should I just report this to Virgin for an engineer to check out?
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 2 of 23
Re: Slow Upload speed - KT4 area
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum!
davestretch
  • 11
Message 3 of 23
Cable Modem Status
Online
DOCSIS 3.0
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
32
4
DOCSIS 3.1 channels
0
0
davestretch
  • 11
Message 4 of 23
4162750000-1.79999938.983261QAM2564
5170750000-2.29999938.605377QAM2565
6178750000-2.59999838.605377QAM2566
7186750000-2.29999938.983261QAM2567
8194750000-2.50000038.983261QAM2568
9202750000-2.59999838.983261QAM2569
15250750000-2.29999938.983261QAM25615
16258750000-2.00000038.983261QAM25616
17266750000-2.50000038.983261QAM25617
18274750000-2.70000138.983261QAM25618
19282750000-2.29999938.983261QAM25619
20290750000-1.79999938.983261QAM25620
21298750000-1.20000138.983261QAM25621
22306750000-1.70000138.605377QAM25622
23314750000-2.40000238.605377QAM25623
24322750000-2.79999938.605377QAM25624
25330750000-2.29999938.983261QAM25625
26370750000-1.50000038.983261QAM25626
27378750000-1.09999838.983261QAM25627
28386750000-1.09999838.605377QAM25628
29394750000-0.90000238.983261QAM25629
30402750000-0.90000240.366287QAM25630
31410750000-1.00000038.983261QAM25631
32418750000-1.00000038.983261QAM25632
33426750000-0.90000238.983261QAM25633
34434750000-1.09999840.366287QAM25634
35442750000-0.90000240.366287QAM25635
36450750000-1.09999838.983261QAM25636
37458750000-1.20000140.366287QAM25637
38466750000-1.29999940.366287QAM25638
39474750000-1.29999938.983261QAM25639
40482750000-1.20000140.366287QAM25640
3.0 Downstream channels
4Locked38.98326100
5Locked38.60537700
6Locked38.60537700
7Locked38.98326100
8Locked38.98326100
9Locked38.98326100
15Locked38.98326100
16Locked38.98326100
17Locked38.98326100
18Locked38.98326100
19Locked38.98326100
20Locked38.98326100
21Locked38.98326100
22Locked38.60537700
23Locked38.60537700
24Locked38.60537700
25Locked38.98326100
26Locked38.98326100
27Locked38.98326100
28Locked38.60537700
29Locked38.98326100
30Locked40.36628700
31Locked38.98326100
32Locked38.98326100
33Locked38.98326100
34Locked40.36628700
35Locked40.36628700
36Locked38.98326100
37Locked40.36628700
38Locked40.36628700
39Locked38.98326100
40Locked40.36628700
davestretch
  • 11
Message 5 of 23
3.0 Upstream channels
12580000038.0000005120 KSym/sec64QAM11
23940000039.2500005120 KSym/sec64QAM4
34620000040.2500005120 KSym/sec64QAM3
43260000038.5000005120 KSym/sec64QAM5
1US_TYPE_STDMA0090
2US_TYPE_STDMA0040
3US_TYPE_STDMA0000
4US_TYPE_STDMA0040
davestretch
  • 11
Message 6 of 23
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.0
Config file
cmreg-vmdg640-bbt062-b.cm
SFID
85590
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
85589
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
davestretch
  • 11
Message 7 of 23
Tue Jun 15 03:38:19 20215Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:39:37 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:39:37 20213SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:39:42 20216CM-STATUS message sent. Event Type Code: 2; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:39:43 20215Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:41:51 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:41:56 20216CM-STATUS message sent. Event Type Code: 5; Chan ID: 23; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:41:57 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:42:01 20213SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:42:02 20216CM-STATUS message sent. Event Type Code: 4; Chan ID: 6; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:42:03 20213SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:42:09 20215Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:43:23 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:43:37 20213SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:43:38 20216CM-STATUS message sent. Event Type Code: 2; Chan ID: 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:43:41 20215Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:44:41 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:45:04 20213SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:45:09 20216CM-STATUS message sent. Event Type Code: 4; Chan ID: 7; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:45:10 20215Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:46:35 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:46:37 20213Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:46:38 20213Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:46:38 20213No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:46:39 20213Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue Jun 15 03:46:39 20213Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
davestretch
  • 11
Message 8 of 23
Hi - I have posted the information from the router below and set up the Broadband Quality Monitor
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Message 9 of 23
Brilliant!- The power levels look fine bur the T3 timeouts are a concern!
Are there any local outages?
The most useful and up to date info comes from the 0800 561 0061 number. Try that to see if there are any faults that the web service hasn't picked up!
davestretch
  • 11
Message 10 of 23
Just called the 0800 number and no service issues in my area currently.
Would you suggest I contact Virgin directly to get them to look at this in more detail?
