hubbinslfc
  • 24
Message 1 of 15
Slow Upload Speed
Hi.
Recently I've been getting inconsistent upload speeds. Should be getting 36Mbps but on average only getting around 10Mbps. Download speed has always been fine. Seems to be worse during working hours, so may just be network congestion in the area. All speedtests have been completed hard wired. Can anybody technical please check the attached and verify all levels are normal. Thanks.
1298750000-2.937256 qam21
2138750000-336256 qam1
3146750000-336256 qam2
4154750000-336256 qam3
5162750000-3.237256 qam4
6170750000-3.236256 qam5
7178750000-336256 qam6
8186750000-336256 qam7
9194750000-337256 qam8
10202750000-337256 qam9
11210750000-3.237256 qam10
12218750000-3.237256 qam11
13226750000-3.437256 qam12
14234750000-3.238256 qam13
15242750000-2.737256 qam14
16250750000-2.537256 qam15
17258750000-2.537256 qam16
18266750000-2.238256 qam17
19274750000-2.438256 qam18
20282750000-2.538256 qam19
21290750000-2.738256 qam20
22306750000-2.738256 qam22
23314750000-2.538256 qam23
24322750000-2.938256 qam24
1Locked37.62500
2Locked36.636790
3Locked36.67210
4Locked36.66470
5Locked37.36150
6Locked36.68118
7Locked36.69733
8Locked36.66340
9Locked37.65130
10Locked37.65832
11Locked37.34930
12Locked37.64230
13Locked37.63940
14Locked38.63570
15Locked37.93230
16Locked37.32940
17Locked37.62660
18Locked38.62340
19Locked38.62540
20Locked38.62350
21Locked38.91990
22Locked38.62440
23Locked38.62140
24Locked38.61820
hubbinslfc
  • 24
Message 2 of 15
Re: Slow Upload Speed
1 53700000 48.5 5120 32 qam 1
2 32600000 48.2 5120 16 qam 4
3 39400000 48.2 5120 16 qam 3
4 46200000 47.7 5120 16 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 1 0
  • 6.09K
  • 512
  • 1.57K
Message 3 of 15
<snip>
There is a problem with your Upstream, all 4 channels should be 64QAM.  This usually is an indication of noise ingress on the line.  VM will need to fix this.  You could try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 in case it's a small local area problem.
hubbinslfc
  • 24
Message 4 of 15
Many thanks for the reply. I've checked and there aren't any faults in the area.
Is the only way to get VM to check the fault by phoning them to arrange a visit or can I request tech support on here? Thanks.
  • 6.09K
  • 512
  • 1.57K
Message 5 of 15
@hubbinslfc wrote:
<snip>  Is the only way to get VM to check the fault by phoning them to arrange a visit or can I request tech support on here? Thanks.
If you wait here a day or two a VM Mod will pick this up.
hubbinslfc
  • 24
Message 6 of 15
Thanks again.
Upload speed has been fluctuating most of the day but seems okay now and the modulation has changed to 64QAM. I've not reset or changed anything.
Do you or anyone else know whether this is normal or can something external cause interference?
hubbinslfc
  • 24
Message 7 of 15
1 53700000 48.5 5120 64 qam 1
2 32600000 47 5120 64 qam 4
3 39400000 48.5 5120 64 qam 3
4 46200000 48.5 5120 32 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 1 0
hubbinslfc
  • 24
Message 8 of 15
Any VM Mod's going to pick this up for investigation please?
hubbinslfc
  • 24
Message 9 of 15
Does this graph help at all? Trying to video and conference call during the day is a pain. Upload speed is up and down constantly.
Anyone from Virgin able to help or do I need to suffer the dreaded call centre?
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d1ecb4422d26bb8512d33edd29bedacc9f8a2a15-13-01-2022
John_GS
  • 14.4K
  • 737
  • 1.34K
Message 10 of 15
Hi hubbinslfc
Thanks for posting and apologies for the upload speed issue. There is an SNR (signal to noise ratio) issue that you are affected by. The fault reference is F008853234 and the estimated fix date is the 31st January. Please monitor the connection for me and let me know if still an issue after this time.
Best,
John_GS
