Alison_clayto38
  • 13
Message 1 of 23
Slow Upload Speed
Both my download and upload speeds were rubbish today 0.24Mbps and 0.11Mbps!!
I reset my router (pin in the hole) and the download speeds have got better (but are still what I would consider to be low for what I would expect on the M100 package (ie mid 20s to mid 30s Mbps).
My upload speed remains very poor indeed, most recent test shows 1.4Mbs
I can see from other threads that other people are experiencing the same problem.
I have been to 192.168.0.1 on my browser and have got the following info
General Configuration Network Access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode EuroDOCSIS 3.0
Config File
Primary Downstream Service Flow SFID 1186712
Max Traffic Rate 117000047 bps
Max Traffic Burst 42600 bytes
Min Traffic Rate 0 bps
Primary Upstream Service Flow SFID 1186711
Max Traffic Rate 10500047 bps
Max Traffic Burst 16320 bytes
Max Concatenated Burst 16320 bytes
Scheduling Type Best Effort
First Time Last Time Priority Error Number Description
14/01/2021 15:57:31 GMT 14/01/2021 15:57:31 GMT Error (4) 68010302 DHCP WAN IP - 82.20.15.43
14/01/2021 15:56:28 GMT 14/01/2021 15:56:28 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Critical (3) 82000200 No Ranging Response received - T3 time-out
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
14/01/2021 14:43:07 GMT 14/01/2021 14:43:07 GMT Error (4) 68010302 DHCP WAN IP - 82.20.15.43
14/01/2021 14:42:02 GMT 14/01/2021 14:42:02 GMT Error (4) 68000407 TOD established
14/01/2021 13:56:14 GMT 14/01/2021 13:56:14 GMT Error (4) 68010302 DHCP WAN IP - 82.20.15.43
14/01/2021 13:55:11 GMT 14/01/2021 13:55:11 GMT Error (4) 68000407 TOD established
14/01/2021 10:06:21 GMT 14/01/2021 10:06:21 GMT Error (4) 68010300 DHCP RENEW WARNING - Field invalid in response v4 option
10/01/2021 22:06:13 GMT 10/01/2021 22:06:13 GMT Error (4) 68010300 DHCP RENEW WARNING - Field invalid in response v4 option
07/01/2021 10:06:06 GMT 07/01/2021 10:06:06 GMT Error (4) 68010300 DHCP RENEW WARNING - Field invalid in response v4 option
03/01/2021 22:11:46 GMT 03/01/2021 22:11:46 GMT Error (4) 68010300 DHCP RENEW WARNING - Field invalid in response v4 option
31/12/2020 11:24:13 GMT 31/12/2020 11:24:13 GMT Error (4) 68010302 DHCP WAN IP - 82.20.15.43
Tags (3)
Alison_clayto38
  • 13
Message 2 of 23
Re: Slow Upload Speed
I have been monitoring all the similar threads in this forum, and people seem to be getting extra data (on http://192.168.0.1/RouterStatus.html?) which I do not seem to be able to see.    Does the information provided change according to which Hub you have?
My speeds have been very variable today. currently, they look pretty good, but typically they dropped right down as soon as I had to be on a work Teams meeting.   My neighbour (also on Virgin) has been having similar problems.
Alison_clayto38
  • 13
Message 3 of 23
and should my BQM look like this?  I wish I knew more about this stuff!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 23
To get into the Hub data type 192.169.0.1 (or 192.168.100.1 in Modem Mode) and press enter.
If you have never gone into the initial Hub settings you will need to log in using the Settings Password on the base of the Hub and go through the initial setup. Once completed log out and you will see a text link for 'Check router status'.
Router-Status-01
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 23
Deleted
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 23
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
Alison_clayto38
  • 13
Message 7 of 23
Ah, I think the info required may be...
Modem Initialisation
Stage
Status
Downstream Acquisition
Locked
Primary Frequency
411000000 Hz
DHCP
Done
TFTP
Done
Time Of Day
14:01:09 GMT
Security
BPI+
Counters T1,T2,T3,T4,Sync,Resets
000,000,002,000,000,000
Internet Connection
IP Address
Status
WAN IP Address
[MOD EDIT: PERSONAL INFORMATION REMOVED]
Lease Time Remaining
5 days 20h:05m:30s
Expiry
Thu 21 Jan 10:06
Current Network Time
Fri 15 Jan 14:01 GMT
Downstream Channels
Lock Status
Channel ID
Frequency
Modulation
Rx Power
RxMER
Pre RS Errors
Post RS Errors
Locked
1
411000000 Hz
256 QAM
5.8 dBmV
 39.0 dB
1295
0
Locked
2
419000000 Hz
256 QAM
5.5 dBmV
 38.6 dB
1093
0
Locked
3
427000000 Hz
256 QAM
4.9 dBmV
 38.3 dB
589
0
Locked
4
435000000 Hz
256 QAM
5.0 dBmV
 38.6 dB
240
0
Locked
5
443000000 Hz
256 QAM
5.1 dBmV
 39.0 dB
1
0
Locked
6
451000000 Hz
256 QAM
5.0 dBmV
 39.4 dB
0
0
Locked
7
459000000 Hz
256 QAM
5.2 dBmV
 39.4 dB
1
0
Locked
8
467000000 Hz
256 QAM
5.2 dBmV
 39.4 dB
0
0
To reset the Pre and Post RS error counts please use the Downstream screen under the router status screen available from the login page.
Upstream Channels
Lock Status
Channel ID
Frequency
Modulation
Tx Power
Mode
Channel Bandwidth
Symbol Rate
Locked
2
39400000 Hz
ATDMA
42.5 dBmV
64QAM
6400000 Hz
5120 Ksym/sec
Locked
3
32600000 Hz
ATDMA
42.3 dBmV
64QAM
6400000 Hz
5120 Ksym/sec
Locked
4
25800000 Hz
ATDMA
41.8 dBmV
64QAM
6400000 Hz
5120 Ksym/sec
Locked
1
46200000 Hz
ATDMA
42.5 dBmV
64QAM
6400000 Hz
5120 Ksym/sec
 [MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 23
Alison_clayto38
  • 13
Message 9 of 23
My BQM
Direct link
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 23
What is your contracted speed ?
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
