Hi, the issue I'm currently having is in relation to my upload speed.
To stream as a broadcaster twitch requires a consistent upload speed otherwise frames of the video feed are dropped.
I have a 21 Mbps upload speed and far exceed the 6,000Kbps (6Mbps) upload speed that twitch requires, however my upload speed is very inconsistent.
Currently and recently I've seen my bitrate to twitch fall to 200Kbps and bounce between 200Kbps and 6,000Kbps causing as many as 35% of the frames sent to twitchs servers to be lost/dropped.
I've streamed on twitch for many years and this loss of upload speed is a recent issue, all of my other hardware is perfectly capable and has been capable of streaming at 6,000Kbps(6Mbps) in the past.But now YouTube and Twitch have this same upload issue
I had a Technician from Virgin Media check my Coax cable on Saturday and he requested another technician to repair a fault in the road outside my house the first technician stated that the "low end frequencies" were practically "non existent" and that it should be sorted after the fault is corrected in the road.
The second technician has now been and the ticket raised for the road fault is ended but the problem is still there.
I then called tech support who said they'd monitor my connection and email me their findings.
Any help with my situation would be appreciated, I feel like I don't have a question to ask other than can anyone help me find a solution to this problem?
Some additional info would be that my Hub shows a constant orange light and there are no other blinking or flashing lights, as I mentioned the first technician disconnected my coax cable from the hub and tested it without looking at the hub , so could this issue purely be that the hub is in need of replacement? I've attached a photo of the hub
The PC I'm streaming from is on wired ethernet and is more than capable of streaming at 6,000kbps and has done in the past (Ryze 5 5600x and RTX 3070) so it's not an issue with the encoding bitrate, Twitch Inspector states that it's the network connection and not the encoding as well to rule out encoding as a factor.
Again thanks to anyone who reads this and suggests a solution, I'm going to call again tomorrow and suggest a replacement router and see how that goes.
