Thorw
Slow UK work VPN Speed only 10-20 % of actual bandwidth
Hi had HUB3, now HUB 4 on 1 Gig  - both with the same issue.
When I connect to my work VPN (London, UK VPN) my speed drops from 950 Mbps to 120-170 Mpbs. Others co-workers in London can connect at 1 gig - but not me ?
I am on wired connection, any help would be much appreciated
Anonymous
Not applicable
Re: Slow UK work VPN Speed only 10-20 % of actual bandwidth
if you get the full speed without the VPN there is no fault. is your work tunnelling all your internet traffic though the VPN?
Thorw
Hi, thanks for a quick reply, for remote workers, yes - but even when I am the only one connected is still only get 10-20% of speed when I connect to VPN. I should be able to get speed of 1 gig or very close to that - my IT department has also confirmed this?
Anonymous
Not applicable
"should" if you get full speeds without the VPN then that points to the VPN or something between VM and the VPN
Thorw
Thanks I guess it is pinpointing this "something" between VM and the VPN - is there any settings or restrictions on the VM Hub 4 that can be changed so its not slowed down when connected over VPN? - particular VPN in the UK?
Anonymous
Not applicable
no. there are not settings or throttling that would slow down a VPN
