FrancisChudley
  • 8
Message 1 of 8
Slow Speeds & Poor Connection
I had my Virgin Fibre installed on 13/4 and I have never had the quoted download speeds I should have, even on Wired with a Cat6 Cable straight into the Hub3 with no other connections. I am on M500 and average around 160.
I wasn't too bothered as this was still a lot better than what I used to get on BT. But now my neighbours have had Virgin installed next door and ever since then my connection has been terrible, often dropping out and not even being able to load a YouTube video. I find it really suspicious as the Virgin guy knocked on my door on Sat 1st May advising that they needed to run a cable from my Fibre box outside to my neighbours Fibre box and that they would come back on Monday 3rd May to remove it and finish installing my neighbours Virgin. Ever since then my speeds & connection have gone massively downhill.
I will post the logs from the router as I have seen requested in other peoples queries below.
FrancisChudley
  • 8
Message 2 of 8
Re: Slow Speeds & Poor Connection
1 139000000 1 40 256 qam 1
2 147000000 1 40 256 qam 2
3 155000000 0.9 40 256 qam 3
4 163000000 1 40 256 qam 4
5 171000000 1.2 40 256 qam 5
6 179000000 1.2 40 256 qam 6
7 187000000 1.4 40 256 qam 7
8 195000000 1.2 40 256 qam 8
9 203000000 1.2 40 256 qam 9
10 211000000 1.2 40 256 qam 10
11 219000000 1.2 40 256 qam 11
12 227000000 1 40 256 qam 12
13 235000000 0.9 40 256 qam 13
14 243000000 0.7 40 256 qam 14
15 251000000 0.5 40 256 qam 15
16 259000000 0.4 40 256 qam 16
17 267000000 0.2 40 256 qam 17
18 275000000 0 40 256 qam 18
19 283000000 -0.2 40 256 qam 19
20 291000000 -0.2 40 256 qam 20
21 299000000 -0.2 40 256 qam 21
22 307000000 -0.4 40 256 qam 22
23 315000000 -0.2 40 256 qam 23
24 323000000 -0.2 40 256 qam 24
1 Locked 40.3 4 0
2 Locked 40.9 5 0
3 Locked 40.3 4 0
4 Locked 40.9 6 0
5 Locked 40.3 5 0
6 Locked 40.3 6 0
7 Locked 40.3 15 0
8 Locked 40.3 17 0
9 Locked 40.9 4 0
10 Locked 40.3 0 0
11 Locked 40.3 5 0
12 Locked 40.3 5 0
13 Locked 40.3 5 0
14 Locked 40.3 5 0
15 Locked 40.3 4 0
16 Locked 40.9 5 0
17 Locked 40.3 4 0
18 Locked 40.3 4 0
19 Locked 40.3 5 0
20 Locked 40.3 4 0
21 Locked 40.3 4 0
22 Locked 40.9 3 0
23 Locked 40.3 6 0
24 Locked 40.3 4 0
1 53700000 35 5120 64 qam 6
2 39400000 35.3 5120 64 qam 8
3 60300000 35 5120 64 qam 5
4 46200000 35.3 5120 64 qam 7
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053+voc-b.cm
SFID 2842
Max Traffic Rate 575000000
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 2841
Max Traffic Rate 38520000
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
06/05/2021 18:16:12 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/05/2021 18:15:4 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2021 16:40:13 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 14:39:42 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 18:00:58 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 12:16:11 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 12:16:9 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 18:48:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 16:46:11 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 20:30:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 04:46:10 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 23:25:8 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 16:46:9 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2021 23:30:43 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2021 04:46:8 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 21:30:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 16:46:7 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 16:21:6 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
https://www.thinkbroadband.com/broadband/monitoring/quality/share/57fd93dce0509823d5b90ccef6b28099a95f4b01
FrancisChudley
  • 8
Message 3 of 8
1139000000140256 qam1
2147000000140256 qam2
31550000000.940256 qam3
4163000000140256 qam4
51710000001.240256 qam5
61790000001.240256 qam6
71870000001.440256 qam7
81950000001.440256 qam8
92030000001.240256 qam9
102110000001.240256 qam10
112190000001.240256 qam11
12227000000140256 qam12
132350000000.940256 qam13
142430000000.740256 qam14
152510000000.540256 qam15
162590000000.440256 qam16
17267000000040256 qam17
18275000000040256 qam18
19283000000-0.240256 qam19
20291000000-0.440256 qam20
21299000000-0.440256 qam21
22307000000-0.440256 qam22
23315000000-0.240256 qam23
24323000000-0.240256 qam24
1Locked40.340
2Locked40.950
3Locked40.340
4Locked40.960
5Locked40.350
6Locked40.360
7Locked40.3150
8Locked40.3170
9Locked40.940
10Locked40.300
11Locked40.350
12Locked40.350
13Locked40.350
14Locked40.350
15Locked40.340
16Locked40.950
17Locked40.340
18Locked40.340
19Locked40.350
20Locked40.340
21Locked40.340
22Locked40.930
23Locked40.360
24Locked40.340
FrancisChudley
  • 8
Message 4 of 8
15370000035512064 qam6
23940000035.3512064 qam8
36030000035512064 qam5
44620000035.3512064 qam7
3ATDMA0000
4ATDMA0000
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID2842
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
SFID2841
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
06/05/2021 18:16:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/05/2021 18:15:4Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2021 16:40:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2021 14:39:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 18:00:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 12:16:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2021 12:16:9ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 18:48:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 16:46:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 20:30:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 04:46:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 23:25:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 16:46:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2021 23:30:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2021 04:46:8ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/04/2021 21:30:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 16:46:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 16:21:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
FrancisChudley
  • 8
Message 5 of 8
3ATDMA0000
4ATDMA0000
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID2842
Min Traffic Rate0
SFID2841
Min Traffic Rate0
FrancisChudley
  • 8
Message 6 of 8
23940000035512064 qam8
36030000034.8512064 qam5
44620000035512064 qam7
3ATDMA0000
4ATDMA0000
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID2842
Min Traffic Rate0
SFID2841
Min Traffic Rate0
FrancisChudley
  • 8
Message 7 of 8
Corey_C
  • 5.19K
  • 257
  • 446
Moderator
Moderator
Message 8 of 8
Thanks for your post and welcome to the Community Forums, FrancisChudley,
Sorry to hear that you have been having connection issues with your broadband. Has this improved since your post?
We also do have a service checking tool, here, that can check for issues in the area as well as run some diagnostics on your connection and equipment.
Let us know if you need further help.
Cheers,
Corey C
