Gemmapb
  • 6
Message 1 of 7
Slow Speed
Were on the M350 package and normally get the advertised 350 down and 35 up but for the last few days we have been as low as 15 Mbps down and 1 Mbps up.
Checked the service pages and no faults reported, we did however have a couple of outages a few weeks ago, believe a cable was cut when some new houses were getting built.
I have restarted the Hub 3, taken it out of modem mode and done a factory reset and still not getting any better than 90 Mbps down and 20 Mbps up.
Can someone look at the router stats and tell me if there is anything wrong please?
Many thanks.
Cable Modem Status
Item
Status
Comments
195000000
Locked
Ranged Upstream Channel (Hz)
60299974
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
195000000
-4.2
40
256 qam
8
2
139000000
-2.7
38
256 qam
1
3
147000000
-3.4
38
256 qam
2
4
155000000
-3.9
38
256 qam
3
5
163000000
-3.7
38
256 qam
4
6
171000000
-4
38
256 qam
5
7
179000000
-4
38
256 qam
6
8
187000000
-4.2
38
256 qam
7
9
203000000
-5
38
256 qam
9
10
211000000
-4.9
38
256 qam
10
11
219000000
-5.5
38
256 qam
11
12
227000000
-5.4
38
256 qam
12
13
235000000
-5.5
38
256 qam
13
14
243000000
-5.7
38
256 qam
14
15
251000000
-5.7
38
256 qam
15
16
259000000
-5.7
38
256 qam
16
17
267000000
-5.5
38
256 qam
17
18
275000000
-6.2
38
256 qam
18
19
283000000
-5.5
38
256 qam
19
20
291000000
-6.2
38
256 qam
20
21
299000000
-5.2
38
256 qam
21
22
307000000
-5.5
38
256 qam
22
23
315000000
-5
38
256 qam
23
24
323000000
-6.2
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
36198
0
2
Locked
38.6
146193
1921496
3
Locked
38.9
370559
1532231
4
Locked
38.6
214414
1901292
5
Locked
38.9
156221
1922359
6
Locked
38.6
93337
1035298
7
Locked
38.6
160892
1519427
8
Locked
38.6
398274
1164610
9
Locked
38.6
3765
0
10
Locked
38.6
383
0
11
Locked
38.6
3866
0
12
Locked
38.9
9683
0
13
Locked
38.9
52563
0
14
Locked
38.9
87355
0
15
Locked
38.9
241183
0
16
Locked
38.6
234478
1
17
Locked
38.6
195037
0
18
Locked
38.6
148281
0
19
Locked
38.9
29543
0
20
Locked
38.6
13056
0
21
Locked
38.6
120
0
22
Locked
38.9
6
0
23
Locked
38.9
0
0
24
Locked
38.9
0
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60299974
50.3
5120
64 qam
1
2
39399957
48.3
5120
64 qam
4
3
46199988
47.8
5120
64 qam
3
4
53699971
50.3
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
34ncxv9873254k;fg87dsfd;k
SFID
5643
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
5644
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
  • 5.93K
  • 495
  • 1.5K
Message 2 of 7
Re: Slow Speed
Both your Downstream and Upstream power levels are near the limits of acceptable values, and some of the channels have noise ingress, as shown by the PostRS errors.  You will need an engineer to rectify these issues.
The Downstream levels should be between -6 to +10 and Upstream between 34 and 51 by the way.
Gemmapb
  • 6
Message 3 of 7
Re: Slow Speed
Thank you.
I'm guessing it's been something with the building works near-by.
I will try and phone up unless it would be better to for one of the VM staff here to sort out.
Paulina_Z
  • 3.92K
  • 137
  • 281
Message 4 of 7
Re: Slow Speed
Hi @Gemmapb,
Welcome back to our Community Forums! Thank you for your post, and I'm sorry to hear that you're experiencing some ongoing issues with your speeds! I can understand that this can be very frustrating.
I was able to locate your account and see that your upstream and downstream power levels are out of spec and we will need a technician to come over to resolve this problem for you.
In order to have this actioned, I will need to confirm some details with you over Private Message. Please keep an eye our for a Purple envelope at the top right corner of your forum page. I will be in touch soon.
Thank you,
Paulina_Z
Paulina_Z
  • 3.92K
  • 137
  • 281
Message 5 of 7
Re: Slow Speed
Hi @Gemmapb,
Thank you for responding to my Private Message and confirming your details!
I was able to book in a technician appointment for an engineer to take a look at your power levels in more details. I have confirmed the appointment information in a Private Message.
You can also manage your appointment via your online account if needed.
Please keep us updated and let us know how your visit goes! 🙂
Thank you!
Paulina_Z
Gemmapb
  • 6
Message 6 of 7
Re: Slow Speed
All sorted.  Turns out it was a corroded splitter under our floor.
Big thanks to your engineer Tam for trying everything else to make it better before we finally had to lift the flooring.
Thank you for your help.
Tags (1)
Jodi_S
  • 3.83K
  • 189
  • 406
Message 7 of 7
Re: Slow Speed
Thanks for the update Gemmapb,
Glad to hear the engineer tried his best to help resolve this before you had to take up your floor. This would have been a last resort for you, and we are sorry this had to happen.
We will give your praise to the technician Tam for you, and pass this on to his manager also.
If you need any further assistance please come back to us through this channel.
Kind regards Jodi.
