BLackhaWK2211
Slow Speed
Hello,
I'm having consistently slow speeds (10-20mb) . Some times a reset helps, often it doesn't. I've had all of my cables off and checked for tightness.
I had a similar problem earlier in the year and had a technician visit. An intervention 'at the other end' seemed to fix it then.
Any help is greatly appreciated.
Rob
  • 26.52K
  • 2.7K
  • 4.92K
Re: Slow Speed
What Hub do you have?
What speed package are you on?
Are you testing on a wifi device or an ethernet cable connected one?
What device is it - can you test on others?
How are you running the test?
BLackhaWK2211
Re: Slow Speed
Package is 200mb (when working well I get this)
Hub is a 3.0
Range of devices wired/wireless give similar results.
Testings on speed test.net app or website
  • 26.52K
  • 2.7K
  • 4.92K
Re: Slow Speed
OK - are you getting dropouts as well or just speed issues?
Can you post up all the data from the Hub's Downstream, Upstream and Network log pages and set up a BQM - see...
